Gazelle UltimateT10 (chain/cassette) or C380 (belt/hub) and to "+" or "not to +"?
Driftless
I am torn between a Gazelle Ultimate T10 and Ultimate C380 and am seeking advice from the group. I’m told the T10’s gears are more efficient and lighter than the C380, and that it’s easier to change a tire, etc. should you get a flat. I also prefer the T10’s white color compared to C380’s blue and olive colors (2021)–neutral and highly visible. However, the variable shifting and low maintenance carbon belt is very attractive as I live in a very hilly part of the Driftless region of Minnesota-Wisconsin where hills are steep and numerous (100s of miles radius). Snow, rain, salt, gravel…. are all daily realities. I’m also in Minneapolis frequently in a highly urban area (60 miles away). What’s your advice?....this was Court's advice on the thread of his review of the C380, "Hi Craig! Your points about the snow, rain, salt, and gravel did make me lean towards the belt drive and internally geared hub. Hopefully others will chime in here, but you could post the same comment in the EBR forums for Gazelle and might get more engagement :) While heavier, slower to shift, and generally less efficient, the internally geared hub can be durable and offer that shift at standstill feature, as long as you aren’t applying too much pressure when doing so. If you do shift under too much load, you’ll hear it clicking a lot. In that case, just ease off a bit and try not to let the motor activate, this will let the gear settle. Or, you can lift the rear wheel or tip the bike left onto the kickstand and then cycle it gently to apply the shift, and then hop on and continue pedaling again (much as you’d have to do with a traditional chain and cassette, which is my overall preference for all occasions due to easy maintenance, easier shifting, and reduced weight). Hope this helps ;)"... sounds like he recommends the T10. FYI, I like the T10+ but I don't like there isn't a step-through option. The mid-step is still really hard to step over at 5'11" on a large (57) frame and the medium (53) felt too small for me. I hear there is a C380+ coming out at some point. I'm also told that if you're looking for exercise, it's better to stick with the non+ as you have to work a little harder. I'd appreciate your experiences, thoughts and opinions.Thank you!
Are you able to test ride both the derailleur and Enviolo equipped Ultimate models? I like the Enviolo system, I've tried it on Capital bikeshare ebikes here in the Washington, DC, area where I am, and it is nice to be able to shift down gear while climbing hills, I have read the Enviolo doesn't like to shift up to higher ratio under load when you're climbing and that jibes with my experience but you quickly get used to how far to twist the shifter down ratio to get to a comfortable cadence, and shifting down works much better than the Nexus 8 IGH as fitted to the Ultimate C8 model. I have a Nexus 8 on my mid-drive DIY ebike and it needs a couple of seconds pause pedalling or pedal backwards momentarily for it to engage - if you like to keep pedalling while shifting down ratio the Enviolo equipped Ultimate C380 would be my recommendation over the Nexus 8 equipped Ultimate C8 model.
The big advantage of both IGH models is you can shift gear when you are stationary, which helps when you are riding in traffic and make frequent stops for a light. You can train yourself to shift down on a derailleur bike before coming to a stop, but in traffic your head is on a swivel and you're processing lots of external stimuli, on my old derailleur ebike I found I was coming to a stop frequently in too high a gear, which is why I switched to an IGH, but after shiftig gear on my Nexus 8 I feel like I can't trust standing on the pedals without fearing the pedal will slip suddenly causing me to wobble, whereas I had no fear standing on the pedals after shifting down ratio when riding up hill on the Capital Bikeshare Enviolo ebikes.
If I had the money I would be tempted to get an Enviolo ebike but they're expensive to buy, most Enviolo equipped models from Evelo, Gazelle, Tern, Workcycles, or Serial 1, cost over four grand, also if I had a bigger shed I'd be tempted by the Workcycles FR8 MAD City which pairs the heavy duty Enviolo Cargo groupset with a Bafang BBS02 mid-drive (Gazelle specced the Enviolo Trekking groupset on the Ultimate C380 which is fine). Workcycles use an Hebie chainglider in place of a belt, I use a chainglider and it's great at keeping my chain clean in winter, it's as good as a belt for daily riding in all weathers.
Belt drive is a disadvantage IMHO. They are more difficult to change the tube after a flat. The life is estimated at 10000 miles, whereas I got 5000 out of a bog standard KMC chain costing $26 to replace. It rains 200 days a year here, I lube my chain every 2 weeks. Squirt squirt squirt takes about 2 minutes. I use non-detergent 5 W oil. Belts can develop a kink if road trash runs through them. I have no trouble downshifting the derailleur before stops. The only chain cleaning I do is to untangle johnson grass stems or string wrapped up in the sprockets. The oil carries the dirt to the takeup wheels, where it falls off as a sludge, or I scrape it off with a screwdriver if changing a tube. My $26 tires are 2000 mile items.
When the cheapo shimano 7 speed axle on my Pacific MTB came unscrewed, dropped balls, and left me pushing the bike home, I bought an IGH. That would be exhausting if it happened 30 miles from home. The IGH slowed me down 10% averaged over 10 trips before it became unrideable due to shifting into 8th gear every mile. Dont buy a Sturmey Archer S80. The 8 speed shimano axle on this bike has gone 6500 miles without issues. This bike costs more than the $200 bikes that the 7 speed shimano axles are designed for.
You won't get 5000 miles out of a chain on a 9 10 or 11 speed derailleur. The chain is thinner.
True, Workcycles came up with a frame break on the left side they call the 'escape hatch' that lets you change a tube without needing to remove the rear wheel or touch the Enviolo drivetrain.
Having just bought a gazelle 380+ mid step, and having test road gazelle; bulls, R&M, Tern, chain and belt drive bikes with both IGH and CVT, I can adamently say that a belt and cvt is beyond smoother quiter and feels 21st century vs derailer system which reminded me of my bike I did my paper route on as a kid. I can imagine why bike shops love chain systems, service income! Like how much the dealers’ service depts hated fuel injection because it cut down their profits from biannual tune ups!
I am glad I went with the plus for when I have to ride with traffic, that being said I prefer the full step through to the mid step 380+ just because. Next up look pedals for my big feet and seat suspension.
Congrats on your new C380+! Still waiting for mine - should be in till end of month.
Very good looking Bike! So you decided to go with the belt drive system I see.. I suspect that this will become more common for ebikes in the future.
Congrats and enjoy!!
Make sure the dealer knows how to adjust cabes for nuvinci n380 cvt on shifter, they need .5-1.5 mm of slack, when in low gear adjust cable nearest seat(underdrive cable) and in high gear adjust fromtmost cable. Mine did not and were all slacked and shifter was hard and making noise and I opened and saw this.
Gazelle makes lots of non ebike belt drives for european market, just choose netherlands for country when checking out their site/ chamonix and Marco Polo should def be important. Way more quality than priority startup china made bikes.
I am getting in from Propel in NYC - they are very reputable and I already bought from them. But I will double check the shifter myself just in case - thanks for the hint!
I really wanted to buy from them but no stock in large size and even harder in midstep and landy’s was $300 cheaper sooo
The Enviolo setting tool part # CE-HW-TOOL-SM-MLD on the Enviolo Service Tools webpage seems like it would be useful for C380 owners with the Enviolo manual shifter to own to lend to your local bike shop during routine servicing/tune-up's so they can get the cable length right. It seems necessary because there are two different cable lengths because there are two versions of the manual shifter
Good call, I recently replaced my pedals with a pair of Look Geo City Platform Pedals and they are grippy flat pedals for my men's Size 12 feet
Awesome to hear cause I am size 13 and mine come tuesday.
Thank you. Will buy, will do myself!
Greetings, first time poster at a final decision point.
Leaning toward C380 over U T10 because of less maintenance time. Just tired of chain cleaning/lubbing 2 bikes in my older age.
Anybody with an Enviolo wish they had gone derailleur now? Would you do the IGH again?
Any idiosyncrasies with Enviolo I should consider?
Anyone with a derailleur experience an IGH and lust for a new IGH or would you stick with derailleur?
Thoughts on 55 tooth chain ring (or should I say 55 cog belt ring)? Would definitely think something smaller would be better. Who needs a 4.58 top gear on a 20mph ebike?
Thanks!
This January I had my local bike shop replace my Nexus 8 IGH with an Enviolo Cargo CVT hub, here’s a blog post I wrote about my experience, if you have the option I recommend Enviolo.
Glad we got busy on decision today since they are critical to RAGBRAI success. LBS had a C380 in small (wife size) and a U T10 in large to try out. My biggest concern was the feel unpowered; last summer I rode a 2021 Como that just wasn't right for me with the pedal forward geometry (they have reconfigured for 2022).
We loved the feel as soon as we got on them. My wife doesn't usually like different; she loved the IGH. Decision made; now to find C380 in large frame; LBS checked with rep. 2023! Started calling other dealers from close to far. 2nd call 70 miles away; has one on order, unknown delivery date. 9th call 148 miles away; still in the box, will build and call in a few days. Glad CC company pays attention to abnormal CC use, rejected charge, fixed with a text. Jackpot.
