COLEEN - The Ultimate Class 3 Ebike
Ebiker01
This is it...cabron fibre frame , pinion gearbox, french quality, authentic character , 21st century deisgn and tech. , also HD display, GPS ,etc....
42lb, 522WH 👍 🥇
Stromer you will soon be forgotten . Bye !!
The model i like : Modern DB
I did some work and here's the translated page:
If there's one Class 3 ebike that truly is worth 10.000 Euros , then this is the one.
Now, does anybody know if the speed could be delimited ? I'm sure once it gets more familiarity on the market some will find a solution . 30-32mph top speed would be just right for Us.
Only video i could find that shows the custom made components and High Quality of this brand . Custom made pedals, knobs , french made motor ,charging port on top of the down-tube...just perfection .
I see that it also has Supernova lights front and rear.
The other models start at 6800euros which is very reasonable imo .But i like the Modern DB, i would add the optional front suspension , rear rack, and have the optional fenders in black .
Very interesting but two things worry me, the beam construction/ lack of triangulation and the French built motor....is it a proven reliable motor?
Might be great or ??,
I like pinion + hub combination and a light bike but they used 6 speed pinion which barely has %300 range. Pinion 9 seems to be the sweet spot for ebikes with %568 range, and 9 speeds is more than enough.
I am also a bit worried about frame stiffness/durability in that design.
42lb, 522WH 👍 🥇
Bro, anything more that 28mph and I would want you to be licensed!
Wha..? You don’t want the old school chrome rack and fenders?🤨
If Bergholt Stuttley Johnson were French he would connect a pinion box to a rear hub motor.
Looks like there's a LOT of carbon fibre overall, esp. In the the top tube/down tube/seatube Junction . And i'm sure it's expertly layered in diff. directions.
The only DISLIKE I have so far is with the charging port on the top tube, it looks like it prvides a perfect seal but let's say you ride this e bike for many hours in the rain , or while having the ebike parked someone lifts the port and messes with the connectors ??
Would be great if @Court could get his hands on one of these and do a full review .
Vous admirez les créations de Bergholt Stuttley Johnson?
Looks like it is listed Available as an option
