voidedwarranty
I just got my first ebike, a Biktrix Juggernaut with a Shimano Deore 10 speed with trigger shifters. The adjustment out of the box was horrendous. Bad shifts all over. I've watched the Park Tools youtube video several times on adjusting rear derailleurs. After attempting the adjustments myself I think I got it to like 90%. Looking for that last 10% and need some help with anyone who has dealt with these derailleurs before.
So first I set the H limit as noted in the video, while in top gear I adjusted it inwards until I heard chain rubbing then turned it back out. The H limit appears to be good.
I have struggled with the index adjustments. And the L limit adjustments. In the Park Tools video there was a cable tension dial at both ends but this setup only has it at the shifter. There is also an "on/off" lever that I have no idea as to what it's purpose is. While riding I have it in the "on" position. All my upshifts feel good. The downshifts are a big source of aggravation. They either don't shift at all, grind then thud into the next lower gear, or sometimes feel like I'm dropping more than one gear.
I also ran in to an issue while riding off a standard size sidewalk curb. The chain felt like it jump down 2 gears and got hung up in-between gears. Lots of bad noises. Could this be a problem with the B limit screw? Or poor tension elsewhere?
Any insight is appreciated. Biktrix has not been very helpful. They wouldn't even give me a model number for the derailleur after asking point blank, "what is the model number of the derailleur". Their response was, "it's a Shimano Deore 10 speed".
