The rear brake seems too loose to work, which is quite dangerous! And I tried to use the tool to tighten the rear brake, however, the NCM stupid design makes it impossible for the tool to stick in and tightens it. Any idea how does it work or do i have to buy a specific tool or find a bike store to get it done?
Adjustment only takes a set of allen wrenches which should be part of any bike tool kit. That said, I have to say, I´m very disappointed with
the stock rear brake on the moscow. Your problem is not with the mounting  bolts for the brake body, but with the adjustment bolts.
Mounting bolts are at a right angle to the wheel; the adjustment bolts are parallel to the wheel. Having done so today, I replaced the whole
damn brake body with an Artek 160mm. Installing & fine tuning the adjustment is a kinda delicate procedure. If you´ve never worked on
disc brakes I suggest having a professional deal with it. I noticed on the old body I took off that the mounting base had been back cut
a file. I had already had to do the same thing to install the Artek, which I just happened to have left over from a kit for another bike. I´ve had
no issues with the front 180mm, but the 160 rear has been a nuisance since the 1500 mi. mark. If I were you I´d have a professional put
on a better brake body. I am also of the opinion the the rear tire, at least, should be a smart sam plus, & not a regular smart sam.  I´ve not
had a rear tire issue since having done so. I still like this bike a lot, but I hope Leon Cycle will adopt these changes in future.
