D
Deleted member 803
Guest
Correction: Found a command on the Stromer app for "blinking" (front and rear lights) so I will give this a try on tomorrow's ride
Damn, you are right. I wondered what the problem was.i was told the "blinking" is when you lock your bike or unlock it . it blinks a few min and stops , more like a locating device if a field of Str0mer ST2s
On the iPhone. In the App go to Tuning, touch the arrow next to the current tuning setup (near the top right of the screen), touch Edit and a delete symbol will appear next to your custom settings, touch that symbol to delete the setting.Went for a ride yesterday starting at the Sather Gate on CAL campus to Treasure Island along the new Bay bridge. Fantastic ride with my son. Got a chance to test out the manual recoup on the bike. I have not been a big fan of this particular aspect of rear hub drives. Accessing the levels of recoup on the fly is not fast and requires numerous presses to the (-) button. I found that level 3 and 4 of recoup literally brought the bike to a stop on a 7% grade. Not sure what the recovery levels are as this is not information that appears to the rider. In other words, I am not sure of the everyday practicality of recoup since I do not see the battery life indicator move. If there is a way to measure in real time, the recoup I would like to know. One thing that I need to address is that the brake pads are loosely mounted in the calipers and if I grab the brake lever normally there is a momentary clack as they make contact with the rotor. My shop tells me that this is a common occurrence and that it does not affect performance. I looked at my brakes and there is definitely some movement of the pads as I can wiggle them just a little. Not a big deal but would like to know if we can remove the clearance and quiet them up. The good news is that the brakes do not squeak. The drive train on the bike is, in my singular opinion just ok. I get some chain slap over rough surfaces and the feeling of the shifts is a little vague. As stated before I have ordered XTR derailleur and shifters to improve. A new shadow derailleur with clutch should help with chain slap.
One other little nit. The lights on the bike are very good quality but offer no options (at least to my knowledge). Wish there was a strobe option for the headlight and tail light. If there is, I do not know how to turn on. Lastly Stromer chose to include flimsy caps for both the charging port and the front USB charger. My rubber cap for the USB port takes some finagling to get it to seat properly. You already know that the charging port cover is substandard.
On the software side, I have set multiple profiles for power level 2 and saved them. Does anyone know of a way to delete a profile?
More later.............
I have an Android app. If you press and hold the preset, the edit/delete menu pops up. Thanks for triggering this. One more question: What does "SIT enabled" in the service menu mean. I have turned the running light on but cannot find any information related to this command. Thanks,On the iPhone. In the App go to Tuning, touch the arrow next to the current tuning setup (near the top right of the screen), touch Edit and a delete symbol will appear next to your custom settings, touch that symbol to delete the setting.
Are you just hitting the brakes or are you manually using recoup and if so, at what level. I found levels 1 and 2 slow the bike considerably and was amazed that level 4 of recoup brought the bike to a standstill. I guess level 4 is for a significant downhill.When all profiles are showing hit edit then delet.
Climb mount Diablo and keep the speed at 15 to 19mph on the way down and you will re-coop 29% of your battery.
It stands for Stromer Integrated Testing. Run it and it will run a complete check on all electrical systems including the USB port, the charging port, the lights, brake lever engine cutoff, the sensor, and of course the motor.Damn, you are right. I wondered what the problem was.
Does anyone know what "SIT Enabled" means in the service settings?
Manual all levels to maintain speed of 15 to 17. I don't want to give up amps to wind resistance by going to fast down. Plus it makes the Lycra crowd feel better to be able to pass me after I smoked them on the way up the mountain.Are you just hitting the brakes or are you manually using recoup and if so, at what level. I found levels 1 and 2 slow the bike considerably and was amazed that level 4 of recoup brought the bike to a standstill. I guess level 4 is for a significant downhill.
I didnt get my mirror so I dont know what it looks like, is that it? they list the contents on the box...or post a picture
The magnetic disc is designed to keep the box closed.............according to Stromer. Funny!I would guess the mirror is mandatory in Europe for high speed bikes and not mandatory here so no mirror, but that is just a guess.. i am ok with picking out one on my own. The dime slug you have??? no real guess, ;looks like a battery but i dont think so and you would probably know if it was...maybe a spacer?/
So are you falling in love with your tricked out Stromer or you still think you will sell and buy a Focus come Jan?The magnetic disc is designed to keep the box closed.............according to Stromer. Funny!
Will still sell and buy a Focus or something else. Going to Interbike with my family and will ride some of the new stuff and report back to you.So are you falling in love with your tricked out Stromer or you still think you will sell and buy a Focus come Jan?
