Here are my starting values with a 52v 17.5ah Battery:
Here are my ending values:
I need to point out that the BMS didn't stop supplying juice to the motor. It was supplying a very small amount. At 51 miles into the trip I had to look down and see if there was any pedal assist. The engine was involved, but very little assistance was provided. Using the throttle or increasing the PAS level didn't increase the pedal assist, so I decided to call an end to this experiment at 51.6 miles.
I'd do the math, but guys I'm knackered. I'll wrap up this post by saying I no longer have range anxiety, and in its place is severe butt soreness. It was around 20 miles to White Rock Lake in Dallas, and each lap around the lake was about 9 miles, and the temperature yesterday was 99 degrees. I ended up doing 3 laps around the lake in my attempt to drain the battery. The Archon Controller decreases the amount of draw from the battery as the battery level drops. I find this a good thing to keep you from being completely dead in the water. I think there's a couple of other things I noticed, but I'll try and add them later after resting up a bit more.
Oh, here's my current odometer mileage after making it home yesterday. After calling an end to the science experiment I swapped out the batteries and headed home, and not pictured is the total mileage for Sunday which came out to 74.1 miles.
I forgot to add this earlier.
Here's the elevation going from my house to White Rock Lake.
Here's the elevation around the lake:
