pushkar
Hey everyone, I wanted to circle back on Supernova lights, off switch.
1. The supernova m99 Pro lights work with the bafang ultra. The brake lights work well.
2. We can also wire the horn, and it sounds loud. It will be good to have if riding in traffic (though I still prefer the slightly gentle Spurcycle)
Light Placement
1. The Moloko loopbar interferes with light placement. We didn’t have this issue with Lezyne macro since you can mount them above the bars.
Please look at this image to tell you how supernova is mounted.
	____We can solve this with Jones Riser OR the Handlebar mount (M99 CRC)
Apologies- I missed this placement issue earlier. So if you have ordered the UC pro with the Supernova m99Pro, there are 2 options
1. If you want the Moloko bar, we can use the handlebar mount. M99 CRC Mount. You can choose your positioning on the front part of the bar.
2. If you WANT a loop bar, and want the position to be on the stem I can swap out the Moloko with the Jones Loop bar with a riser at no cost.
3. If you don't care for the Loop bar,I can give you a nice One up Carbon bar.
>>>>>>>This swap is only available to people who have already placed the ordered the UC Pro with the supernova lights.<<<<<<
On Off Switch for the headlight
1. I installed the M99 Pro and I also confirmed with Supernova that the M99Pro will be always on. They adhere to EURO standards and a speed pedelec (45kmph) requires a DRL (daytime running lights). The toggle switch is for high beam / low beam.
2. I also looked at other powerful lights (over 1000 lumens) - Busch and Muller, Light and Motion, etc and all of them have DRL functionality with no explicit off switch.
Options
1. If you dont have an opinion about the on/off switch, you can keep the Supernova M99 Pro. I always ride with a DRL and I would recommend this.
2. If you NEED the on/ off switch, We can switch you to M99 Mini Pro. This is an excellent light as well with over 1100 lumens !
What action is needed right now ?
1. Please provide your feedback in comments and preferences
2. I will finalize and add these options to the build configurator in late July / August
Thanks.
Light Placement
Options
Thanks.
