FlatSix911
- USA
- City
- Silicon Valley
Here is the detailed review posted on Electrek...
electrek.co
The bike features a Brose drivetrain including a 750 Wh battery hidden in the downtube. Very few electric bikes can tout a battery with that kind of capacity.
BULLS rates the bike with an “umatched 150-mile optimal range,” which translates to 241 km for the rest of the world. The “unmatched” part is (nearly) spot on, though we’ll talk about how realistic that kind of range is in a moment. For power, BULLS went with the Brose Drive S, a mid-drive electric bike motor normally found on electric mountain bikes, thanks to its more rugged design.
The bike is limited to Class 1 speeds, meaning the motor won’t assist past 20 mph (32 km/h), and there’s also no throttle. That means you’ll be pedaling full time. But with up to 410% power amplification in the Brose Drive S, the motor can do most of the work for you if you select the highest power assist level.
The BULLS Lacuba Evo Lite is designed as a premium electric bike and thus features high-end components including a Gates Carbon Belt Drive and a Shimano Nexus 5 internally geared hub. When you’re 2,000 miles into a cross-country trip, the last thing you want to deal with is a busted chain. Plus, between the belt drive inside the Brose motor and the Gates belt drive powering the rear wheel, this has got to be one of the quietest bikes out there.
A 63 mm travel suspension fork provides some cushioning up front, and Shimano BR-MT400 hydraulic disc brakes handle the stopping. Lights, fenders, and a rear rack also come standard, as they should on any eTrekking bike worth its weight (which is 49 lb or 22 kg, by the way). The bike is available in multiple sizes and comes in three frame styles, including wave, diamond, and step-through. You ready for the price? The BULLS Lacuba Evo Lite will set you back $4,799. That’s a lot of trekking.
BULLS announces arrival of new 150-mile-range trekking electric bike
I think it’s safe to say that most of us won’t need to go 150 miles (241 km) on a...
electrek.co
