Help required choosing e-bike
liamS
We are looking for e-bikes to ride around the lake near our home in Texas. Mix of rough paved roads, some gravel and gentle offroad paths. Most other riding will be along roads or sidewalks.
Leaning toward Juicedbikes Ripcurrent S but dont think we quite need that wide a tire which may add some to rolling resistance? Also looking at Specialized Como2.0 but not sure that is rugged enough for a offroad pathway.
Wife and I are mid fifties and need to lose some weight.
The most practical tire for mild off road use is the 26" x 2.1". If you are tall, you can use larger 700 cm or 29" diameter, but don't decrease the cross section below 1.75". Fat tires, 3.1" & above, are more of a fashion statement than a comfort device, IMHO. They are useful for fluffy beach sand and powder snow. Fat tires are reported difficult to get off the rim out on the road when you have a flat. I can change a tube in my 2.1" in 30 minutes. If you're going to go fast you need a suspension on rough roads, but under 10 mph the tire will soak up the bumps. Suspension costs about $1000 extra.
What size body do you have? Bike frames come in sizes and buying the wrong one is uncomfortable.
The internet sales bikes as juiced have a huge disadvantage. If there is a problem, you call the company and request help. Then you fix it yourself. If you buy from a local shop, they should be responsible for solving problems. Electric bicycles are not yet trouble free, and buying what a shop within driving distance stocks helps address that problem. If you are close to Dallas, looking around in those shops should be the first priority. If either is under 66" tall then a proper sized bike will not be in stock, but otherwise you should find something that fits.
The base page without the forum suffix has a shop finder, if you put in your zip code. Others may be found on search engines.
Some brands use cheap "steel" for spokes and break a lot of them on rough roads with heavy loads. Look for this problem on the brand forums for any brand you consider. People obsess over 13 & 12 ga oversize spokes, but actually 14 ga is fine under 25 mph if the steel doesn't contain copper or zinc.
If going Juiced, with more of a city/mountain hybrid in mind, I'm more of the Cross Current type here.
Thanks. I am not afraid of doing the repairs myself but also do not want to buy junk. I am 6'1 and quite large and would like some width in the tires more than a hybrid as I have that now. Maybe 2.5-3" for going through the occasional dirt pathway. Would the mid drive 250W type drive as found on Specialized Como be enough to last a 20 mile ride for a heavy person as compared to a 750 Hub Motor type drive?
Which other mid drive type bike is recommended that has 2.3" - 3" tires?
Re: 20 mile range with hub drive. Obviously going to have to do with bat. capacity. The big 52v 19.5ah Juiced batteries will not have any trouble. Smaller could, especially if you were going direct drive hub. Gear drive rear hub much better at lower speeds, especially in stop and go and small hills. Much peppier feel.
I'm using a Schwalbe 2.00 tire for conditions pretty much as you describe. Great compromise tire that's quiet with minimum rolling resistance.
That Delta looks like a great solution although very expensive. However it looks like they dont have inventory. i did email to ask for a time estimation.
Well, never heard back from Evelo. In any case I just cant afford the Delta x.
I really like the CUBE bikes but doesnt seem there are any dealers in the US.
So my short list is between the Juicedbikes Ripcurrent S and the M2S All Terrain Pro R750.
An alternate would be the Dual Sport Ultra from M2S.
I think Juicedbikes increased the price on this just because of the 52v battery, not sure it is worth another $500.
One problem with M2S is they dont have a Torque sensor.
Any thoughts?
Just one. I agree with the big price difference for that bigger battery. I'd be tempted to pay it, but it seems excessive to me.....
Bang for buck, Juiced is best value in the market. I went with the Ripcurrent and I love it.
I have decided to go with the Evelo Delta X. It is expensive but I'd rather have a bike that is built to handle larger riders. Hopefully it works out well. Thanks for all the advice.
