IT WORKS!
Over the past few months, I converted my 26" mountain bike (MTB) into a rear drive ebike using the kit describer earlier in this thread. After getting everything working on the MTB, I measured the motor's static torque and found it to be 104Nm. This was determined by measuring the maximum static force the MTB could exert using motor only. It was found to be 32kg (314N) with a wheel radius of 0.33m.
With the trisikad conversion still on my mind, I measured the maximum static torque that Erwin (the trisikad owner) could exert using his pedal power only on his trisikad. The result was 74Nm. This was measured similarly to the MTB and the maximum staic force was found to be 30kg (294N) with a wheel radius of 0.25m. It now became apparent that the same conversion kit could be used to convert his trisikad to electric power.
A second conversion kit (the same as the first) was ordered (USD276) and 48V charger (USD10), all from China. Four 12V 16Ahr SLA batteries were ordered (USD100) from Manila. All prices included delivery to Cebu.
Originally we were going to fit the motor to the right-hand (rear) wheel. After observing the operation of the trisikad, I found that when it turns, it does so using the right-hand wheel as its pivot. A right-hand drive wheel was not going to work. We then decided to fit the motor to the left-hand rear wheel.
The first job was to move the band brake on the existing left-hand rear wheel to the front wheel. While doing this, we had our bicycle wheelwright dismantle the left-hand rear wheel and fit the 48V x 1000W brushless non-geared motor. In doing this, he used 10G stainless steel spokes and fitted a new 20" x 2.125" tyre and tube. Total cost USD13.
The now powered left-hand rear wheel was a tight fit into the bicycle's frame but we eventually got it fitted.
Yesterday we completed this project by installing the batteries, controls and wiring. By 6pm all was finished and Erwin took his e-trisikad for its first run. He returned 30 minutes later with that "ebike-grin".
I will get some photos and post them within a day or so.
This is the first e-trisikad that we know of in Cebu province and possibly the first in the Philippines. There are more than 5,000 trisikads in our City of Lapu-Lapu.
