jinim
I received my CCS a little over two months ago, and it has been both a great and poor experience. When I first assembled my bike, I took it for a ride around the block. The first problem occurred as the power to the bike cut out and the LCD display turned off. I immediately contacted Juiced bike support, and they were quick to respond within a day. It turned out I had a bad battery fitment, and they sent me a new socket. Before receiving my replacement battery socket, I duct taped the battery to the frame so the bike would work. I rode it for a week like this before my replacement part arrived. After replacing the battery socket, the bike was working great for about a month.
It's been an excellent commuter bike. I have a 4 mile ride to and from work, and I'm able to get to work faster than if I were to even drive to work. It's got plenty of power for the hills in San Francisco. There's some pretty decent hills around me, especially coming from the gym where I live. Although I didn't test other e-bikes before I bought this, I'm very happy with it; when it works.
I started noticing some problems again a few weeks ago, as the power to the motor would suddenly drop for a brief moment, before resuming again. There was no cut out from the battery light and the LCD remained on. I wound up duct taping the battery to the frame again, and it seemed to resolve the problem temporarily. About a week ago as I was trying to leave work, I turned the bike on, but the battery indicator showed no bars and kept flashing on the LCD. There was no power available to the motor, even though the bike would turn on and the battery was fully charged. I contacted Juiced bike support last Thursday, but this time it took them until this Tuesday to respond. They had me check the connections. It turns out that the plastic piece for the battery connector to the socket on the bike broke slightly at one of the pins. This left a piece of plastic on one of the pins. I saved my old socket and put that on the bike, and the bike worked again with the battery once again duct taped to the frame.
I just rode back from work, and the power to the bike just completely cuts off now as I'm riding it (LCD shuts off and power cuts out). The bike without power is almost unrideable on even low grade hills/inclines. It almost feels like the motor is providing some resistance. I'm not sure how to explain it, but maybe it just feels that way because it's a super heavy bike. It doesn't feel the same though as if I rode a bike with a heavy pack. I kept having to turn the battery and power on and would get power for 30-40 seconds as I rode home today. I was able to have the power stay on long enough in sections to get up some hills and eventually back home.
Yesterday, Juiced advised me to be careful going over bumps to avoid this issue. I've had it for a little over two months; riding it as I would all the other bikes I own. I get that I'm traveling at a much higher rate of speed, but this seems like it's a design flaw. Even with the replacement battery socket, after a little over a month of use, there was some looseness that developed so the battery would move laterally again (bad fitment). I could pull the battery towards me again recently (while it stayed flush initially after replacing the bad part), and the power would cut out. From other e-bikes I've seen, many of them have the power connection at the bottom. This seems like a more logical design, as gravity should help keep the pin/battery connection in place. In addition, the locking mechanism applies pressure on the battery towards the connection. This battery connects at a perpendicular angle, but then the locking pin pushes the battery down. This allows there to be lateral movement on the battery, causing fitment issues. In my case, the battery connector broke off from the movement caused by riding the bike as the bike developed fitment issues again. This is what Juiced wrote me yesterday morning, but I haven't heard a response yet from them. It's been a great bike when it's working, but it seems like there's a design flaw with the battery connection. Hopefully they resolve this. It's a great bike at a reasonable price when I haven't had issues with it.
New reply for the ticket #SU00018894
Thank you for sharing the details. Do you still have the battery box? This way you can send us both the pack and key socket for review while we send you a proper replacement.
We will recommend to prevent this from happening again to be careful while going over bumps. Our bikes are great commuters for the road as long as we do the basic tuneup and prevent excessive wear
Please let us know your comments and we will continue solving this issue asap
