Hopefully not. Bafang error 30 is generally error between display and controller. First check is wire continuity. Check pins to see if any are bent or misaligned. If wires check out, generally this is a controller issue which is not an easy fix.Communication fault can also be hall sensors in the motor. Not just a connection or wire issue.
It's usually that, BUT, hall sensors are part of the control circuit as well. I'm fighting an issue with a Bafang geared hub motor. Sent it to the guy that repairs Sondors motors. Told me it was cold solder joints on the Hall sensors. Rode it less than 10 miles and it coded out again. 2 days latter it works in my garage. No codes showing today, but won't trust that thing on a ride after being stranded 6 miles from my van on a 96 degree day, on a 60 pound single speed fat bike!Hopefully not. Bafang error 30 is generally error between display and controller. First check is wire continuity. Check pins to see if any are bent or misaligned. If wires check out, generally this is a controller issue which is not an easy fix.
I'm not Juice bashing, but after looking at the Juice Support video "How to reach the controller to wire harness plug video" I see many 'points of failure' with the various connectors, some of which don't appear to have sufficient mechanical security to take the rigors of an e-bike. I'm also troubled by the external connectors that appear to run along chain stay.
If I owned a Juiced Bike I would wrap each connector with heat shrinkable tubing to protect the connectors from whatever, plus the tubing
would add some additional mechanical security to what appear to be connectors designed for a less stressful environment then an e-bike. Also I noticed on the Error Code List, seven of the eleven Error Codes say 'Connector and or Cables' as the likely cause of failure.
Unrelated to cables and connectors, Rich C wrote....."Told me it was cold solder joints on the Hall sensors" Cold solder joints are normally a QC issue in manufacturing. Repairing them can be very difficult and since the 'problem' is intermittent there is no way to know for 100% certain if the unit has been 'repaired'.
Rich C summed up well what I described above. " Rode it less than 10 miles and it coded out again. 2 days latter it works in my garage. No codes showing today, but won't trust that thing on a ride after being stranded 6 miles from my van on a 96 degree day, on a 60 pound single speed fat bike! Good luck.
John from CT
John,
Rich was talking about a Sondors motor! not juiced bike![]()
Dean Here. My RCS died on 5/9 and after much BS with Luis, a new ECU finally showed up today. I'll put it in later today to see if it fixes the issue.
This bike simply lost motor control when I took a short break off the bike, no event of any kind occurred. It simply ceased motor function just as I began my 3rd ride. The bike has less than 50 miles on it. There are no error codes at all on the display, in fact, the LCD and headlamp work fine, just no throttle or assist from the motor whatsoever. All cables look perfect- pins are not bent, connectors are tight, no abrasions on any wires, but this issue sure acts like a bad wire.
BTW... This bike came with a bent chainring, which I had to wait 9 days for a new one from Juiced'. I got 2 decent rides in after that event and loved it. Now this problem.
Luis has made this repair especially frustrating for me. Besides being impossible to reach, and taking days to respond to my emails, he's dragged out this repair as long as possible telling me to check cables and connectors and battery fuses multiple times. WTF does he think I've been doing for the last 3 weeks? I did most of this within 10 minutes of the bike dying. I had trouble getting the 2 battery fuses out for inspection, and was afraid I might break them, so Luis made me a video on exactly how to remove them. That's the only helpful instruction he's given me so far.
He sent me a new ECU via UPS Slowest way across the country during the holiday to here in RI where I live. He should have sent all the electronic parts that could fix this via P1 delivery. Not sure why he has been treating me like this, but he's turned Juiced's biggest fan very much off.
@John from Connecticut
John,
I think the video shows the 1st gen ocean current - did it have a teal/blue frame?
I don't think the cables run the same way anymore on the newer frames. I believe the RCS has a channelguide on the bottom of the downtube with a rubber gusset that seals in the wires to keep them from dangling, and then has little hooks-guides the rest of the way back.
The robustness of the connectors at the ECU may be in question if the newest RCS (with in theory the newest setup and ECU) are fragile.
@Guitartec,
If you had checked the controller install when you first got the bike, would you have been easily tell if the controller was mounted correctly?
Was the crushed wires obvious?
Was the stress on the soder connectors only visible if you "cracked" the ECU open?
If you had checked before your first ride, do you think it was fixable -- i.e. did the vibration of riding for 30-40 miles "break" it or was it doomed from the start?
I'm glad the bike is back in working conditions.
Be safe!
You're correct in that these forums are invaluable. They're literally a lifeline for a lot of readers. Whether it be for someone like myself trying to sift through all the information to make my first ebike purchase, or for someone who needs some troubleshooting guidance. Occasionally, we get off course and let our emotions get the best of us on a particular subject, but it's because we're passionate about ebikes. @NeilCruz , I too thought you were putting blame on @Guitartec about checking the ECU, but as I read more of your post I realized you were trying to determine if a poorly installed ECU was something other soon-to-be RCS owners could spot when they got their ride. Great idea.@John from Connecticut
If a number of us all discover the same problem and notify Juiced then they can identify if someone at the warehouse or back in china is doing something wrong and they add checking for that problem to their QA checklist.
As Direct to Consumer bike owners, places like this forum are invaluable - this is OUR LBS, where we can share knowledge so that the next customer might have a better experience.
Superb information above!
BTW, to folks who may be new to this stuff, all greases and oils are dielectric by nature, none conduct electricity.
However, metal to metal contact is made through any oil or grease if the metal parts are brought into contact with each other. Greasing an electrical joint is therefore harmless.
A preferred general purpose and electrical connector grease,
View attachment 22356View attachment 22357
It will not turn hard over time, separate or stain.
A silicone grease is also ideal for electrical connectors because it is absolutely inert and non-aging.
Both types available from Amazon
