JRA
Coinciding with the fact that I have my e road bike scene pretty much dialed I had been looking at options to add a mid drive to my old (2005) 29"er hardtail. It has just been sitting around as there isn't a lot of single track here to ride and that is why I have been riding the road. A kit dealer here in town talked up the TS mid drive to me as the way to go. He offered to let me try his bike out but I am the type that if I am going to try it out I am probably not going to be easy on it so I made a deal with him for a unit.
They come stock 36v but he had some 52v controllers made for it and I had him put one on so I could use my 10.3ah Shark Pack to save some bucks and I can't ride both bikes at once anyway! I have made a pact with myself actually to not buy any more batteries until the 20700 versions appear.
Went together just fine although I did back track a few times as I figured out the best way to route wires etc.. Probably took me 3 hrs. total and a trip to the hardware store for some necessary bits
The display bracket was not going to put it where I thought it should be and it looked kind of fragile like it would snap easily if I crashed. Well it didn't get that far as it broke while I was adjusting it so I took it off and mounted it to the stem and it sits there nicely held in place by a strong rubber band.
Took it around the block to make sure things were operational and after a few tweaks I got my warm gear on and took off for the other side of town where there is a big park with one pretty steep road going up in to it. In fact I over heated a controller on my hub bike going up it last summer and as I said, I don't do easy test rides.
It was 7 miles across town to the base of the climb and in eco mode the bike, even with knobby tires running 15psi got there just fine. In fact I passed a group of road bikers along the way which they must have thought odd. Once on the climb I settled in to my 2nd gear which is like a 32" and tour which is the 2nd setting and went to work on the pedals. The Torque Assist works really well and is very natural feeling while doing a climb. Score 1. Slight growl from the motor under load but not loud enough to bother. Score 2. Cleaned the climb with a good effort on both mine and the motors part. Score 3. You can see it in here:
It was a little greasy up in the park and there was even some snow up on top
I stopped by a shop and bought some mudguards on the way home for next time. Had to put the rear one on in the parking lot because I couldn't carry it easily but the downtube one has yet to make its way on. By the time I got back it was cold enough that all the mud had frozen and the bike is now making a mess on the floor.
Overall I would have to say my initial impression of the TS (http://www.cnebikes.com/product/TS-mid-motor-kit.html) is that it is a very suitable system. The Torque Sensing is on par with any bike I have ridden from the big boys. It has all the power I need for mtb use with enough get up and go to get to the trailhead. Seems to be pretty frugal on watts too as I didn't baby it at all and went as fast as I wanted for the whole ride and used about 450wh. The gauge stayed on full for a long time but when it started to bleed off it went down fairly fast as voltage meters are apt to do. I think I will install my old watt meter on the bike so I can track watts instead.
Pretty economical ride though and all I will ever need. Now I have to put my FS bike back in to service for analog duty!
