J.R.
Member Since 2014
- USA
I'm a big skeptic with regard to what many call "hill". When I read xx% hill I always want to know how long. One city block-long 15% grade is a bump in the road, you likely had a real hill! My bike's 500w DD wouldn't go up a real hill in the way you've described without effort on my part. A geared hub has more torque, but still...Just back from 12 mi. 91 degrees with humidity. I bonked even on the highest level of assist, and even that level felt sluggish today too, (yes, I started with a full battery).
Discovered something interesting (and potentially troubling). I decided to only use throttle to see how the bike would do on a moderate (4% grade) hill. It did awful. The bike struggled to get to 11mph and was actually down to about 7 mph and going slower when I finally started pedaling to help it along. I still had 3 bars left at the point I used the throttle, so it's not like the battery was very low. If I had to depend on throttle only to get home, it would be a very slow ride. Yes, on perfectly level roads and then downhill the bike can get up to it's maximum speed of assist using throttle. On a hill, without pedaling along actively, it struggles and it does so badly.
This is not what others with these 350watt Dapu motors on their bikes report. Everyone says these 350 watt geared hubs can climb well and these geared hubs get you up a moderate hill with no difficulty. Well, not this bike and not this rider. Not without active pedaling.
