Steve Plattner
Hi, I recently bought a LunaCycle 36V charger to use in place of my Stromer ST-1 charger. Why? With Stromer batteries being so expensive, I want to maximize the life of each of the 4 I have (I do long trips) and only charge the batteries up to 90% to prolong their lives.
I disassembled the XLR 4-pin plug on my Stromer charger. As you can see from the attached pix, the power cable leading to the XLR plug on the Stromer charger has two leads--positive and negative. They are soldered and the connections are embedded in what looks like hot melt glue. And, inside the clear glue, you can see a small resistor (pale blue with 4-5 color rings identifying it).
Has anyone else tried to do this? Any thoughts on the resistor? Do you know of any resources who could do this for me--soldering, adding the resistor?
Thanks, Steve
Thanks, Steve
