Yuba Ring
Andrew S.
Has anyone purchased the Yuba Ring? More specifically, will it fit and are the mounting holes on our wood decks the same distance apart as the mounting holes on the ring? Thanks in advance.
Hi Andrew,
I checked today and the holes do not line up. You could probably drill new holes in the deck to allow it to fit if you were confident in the strength of the wood deck.
I ended up installing a ring on the aluminum cargo deck. It's working well so far- not sure if I want to add a railing of some sort like the Caboose for extra support.
