x3 pro display manual
PSA: From the tests I have done with SDH set to to 50 (on), in Power Set (does not matter which group) [1% to 57%]=[no regeneration] and [58% to 100%]=[regeneration] on any PAS level that is not zero and only above aprox. 12.5 mph when coasting. If WALLKE has advised you to turn off SDH, then I would listen to them to avoid damaging you components. I am providing this information for the purpose of covering what is not in the manual, and not to open a repeated discussion about regen itself. There are other threads for that.
