where to buy cheap battart for ncm?
I don’t think you will find anywhere cheaper than the Canadian Leon Cycles website . I’m in uk and batteries have not been in stock for a long time - the cheapest I could find was on AliExpress but that cost more than the Canadian site
Aijiu sells batteries for all the NCM bikes. The sales rep @Jenny Mao here on EBR is well respected. I've bought a 25ah battery from her and they use Samsung top of the line cells inside and Jenny will walk you through everything needed to make sure you get the right battery for your bike and at a terrific price.
Search for Dorado 25ah and you will see my review of the battery and lots of discussion of Aijiu and the batteries they sell.
I'd avoid all Aliexpress retailers unless you've heard good things from other people and can verify the quality of the cells inside. Aijiu is through Alibaba but I verified the cells inside, the quality of the construction (pure nickel strips with good welds and double wrapped for better insulation (prevents shorts). I've ridden it on rough trails, long distances and more and the battery is perfect!
Thank you @Bitmugger @Timpo for keep recommending us.
It is noticed that the Dorado Max 505L 48V 15Ah used on NCM T720, and 48V 21Ah used on NCM T1000, both coming with 750W motor.
Hi @ray star , we have 48V 25AH/21AH/17.5AH options for NCM T720 battery replacemnt.
With the same Dorado Max case, we can do 48V 21AH by Samsung 35E cells, with 30A BMS for 1000W motor.
And with upgrade Dorado 21700 case, 48V 25AH by Samsung 50E cells, with 30A BMS for 1000W motor.
Also with degrade Dorado Plus case(with side handle), 48V 17.5AH by Samsung 35E cells, with 25A BMS for 750W motor.
Considering the clerarance for battery is limited on T720 , and the upgrade 25Ah battery is 5mm higher than T720 current Doraod Max battery, weight 6kgs,
so the 25Ah might be a little bit tight and hard for detaching, no side handle for help likewise the Dorado Max.
But it is worth trying the huge capacity battery to be free of range anxity per charge. 😊
你好! 谢谢! 请问我在加拿大,怎么向你们购买呢? 电池费用多少呢? 谢谢啦!
哈哈,在这里发中文是不是不太友好啊,可以私聊, 😊 这是我们阿里巴巴店铺的链接,可以发询价或者发信息给我,然后我就可以按我们协商型号和价格给您做订单。
您可以选择PayPal,信用卡或者借记卡支付。 谢谢支持!
Just a FYI to those who want to buy battery from NCM Canada, I bought one battery for my Moscow and it’s not comparable to my 1 year old original battery, the replacement one can only run 2/3 of length if not less than my 1-year old original battery. I will not recommend anyone to spend the money.
