While many are happy with those budget drives, they are featureless compared to eBikes.ca motors.
Most budget DD motors are clones. Copying 9-Continent. Yes the kits are twice the price wanting to pay but everything about Grin kits is superior. I really like my Grin controllers. I can run any of my batteries, 36V, 48V, and 52V.
YOUR CUSTOMIZATION
FH212 Ready-to-Roll Kit
In stock
USD$708.40
$825 shipped without a battery.
OM WHEEL BUILD None Sapim Strong 13-14g Butted Spoke, Silver +USD$32.40 Sapim Strong 13-14g Butted Spoke, Black +USD$39.60
Custom Cut Silver Pillar Spoke, Butted 13-14 Gauge, Specify Length at Checkout, Includes Nipple
Click Here for detailed product info page
SELECT RIM FOR CUSTOM WHEEL BUILD None Rim20J31 +USD$50.00 Rim20_Fat +USD$40.00 Rim20_Alex +USD$24.00 Rim24J31 +USD$50.00 Rim24_P17A +USD$25.00 Rim24_Alex +USD$24.00 Rim24_Fat +USD$40.00 Rim26J31 +USD$40.00 Rim26_Fat +USD$40.00 Rim26_DM18 +USD$24.00 Rim26_ZAC19 +USD$30.00 Rim26_Alex +USD$24.00 Rim700_ZAC19 +USD$30.00 Rim275_Alex +USD$30.00 Rim700_DM18 +USD$24.00 Rim700_Alex +USD$24.00
26" DM24 Alex Rim Black, 32mm Wide with Stainless Steel Spoke Eyelets. Compatible with both disc and rim brakes.
INCLUDE DISK ROTOR? None Magura 6-Bolt Rotor 160 +USD$18.00 ETA: Jun 11 2021 Magura 6-Bolt Rotor 180 +USD$12.00 Magura 6-Bolt Rotor 203 +USD$12.00
DOWNTUBE BATTERY CHOICE None B3615Li-DT +USD$375.00 B3617LiM-DT +USD$600.00 B3620Li-DT +USD$485.00 B3626LiM-DT +USD$860.00 B4816LiM-DT +USD$690.00 B5215Li-DT +USD$430.00 B5220LiM-DT +USD$880.00
CHARGER MODEL None 36V 2A ST3 Charger +USD$25.00 36V 4A ST3 Charger 100-240VAC +USD$75.00 52V 4A ST-3 Charger 100-240VAC +USD$86.00 Satiator Upgrade with ST3 Adapter +USD$220.00
52V 4.0A Lithium Battery 3 pin ST connector Charger from ST
CONTROLLER data-validate = {required:true}> Choose a selection Baserunner_L10 +USD$160.00 ETA: Jun 10 2021 Phaserunner_L10_Bk +USD$220.00 ETA: Jun 10 2021 Phaserunner_L10 +USD$220.00 C4825-L10 +USD$100.00 C4835-L10 +USD$95.00 C7240-L10 +USD$135.00
48V-52V, 35A Sinewave Controller with ON/OFF switch, Proportional Regen, and CA3 Connector. New Model with Waterproof L1019 Connector for Motor Plug and WP8 Cycle Analyst Connector. For direct-drive motors only, does not work well with high power geared hubs like the GMAC or eZee. Full Product Information Page
V3 CYCLE ANALYST
V3 Direct Plug Cycle Analyst with Waterproof 8 Pin HiGo CA Plug for Ready to Roll Kits.110 cm cable length. Full Product Information Page
CA MOUNTING BRACKET STYLE None CA_SteerBracket +USD$7.00 CA_Bracket +USD$10.00
INCLUDE AUXILIARY INPUT AND POWER SWITCH
Multifunction Switch for CA3-WP, with On/Off Power, Up/Down Digital Aux Buttons, and Screen Toggle. 45 cm cable length.
FRONT MOTOR EXTENSION
60cm Motor Phase Extension Cable with Male and Female L1019 Plug
THROTTLE CHOICE None T-Lever_50cm +USD$11.00 T-CLever_50cm +USD$15.00 T-HTwist_Slim_50cm +USD$15.00 T-LHTwist_Slim_50cm +USD$15.00
50cm Thumb Lever Throttle, Universal Left / Right Side Design. Short Cable for Connecting to Cycle Analyst.
PEDAL SENSOR TYPE None PAS_12P +USD$21.00 PAS_12P_Chr +USD$21.00 PAS_24P +USD$16.00 ETA: Jun 16 2021 ERider68_4B +USD$110.00 ERider68_5B +USD$110.00 ERider73_5B +USD$110.00 ERider73_4B +USD$110.00 Sempu_140 +USD$100.00 NCTE_136 +USD$105.00
CA3 Compatible Quadrature PAS Sensor, Split 12 Magnet Ring for Square Taper Spindle Mount
TORQUE ARM? None TorqArm_V2 +USD$14.00 TorqArm_V3 +USD$21.00
GRIN Front Torque Arm for Mounting on Forks with Fender Eyelets. Thick 1/4" Stainless Plate. Full Product Information Page
EBRAKE LEVERS FOR REGEN? None EbrakeWuxD_50cm +USD$18.00 TripWire_Pull +USD$30.00 TripWire_Push +USD$30.00 Magura MT7e Brake +USD$175.00
Dual Left and Right Ebrake levers with Single JST Connector
INJECT MOTOR WITH STATORADE BEFORE SHIPPING? None Inject Motor with Statorade +USD$15.00
* Required Fields
YOUR CUSTOMIZATION
In stock
USD$708.40
Add to Cart
SUMMARY
- Motor Winding Option:
1 x FH212_Std
- Include a Wheel Build?:
1 x WheelBuild
- Select Spokes for Custom Wheel Build:
36 x Sapim Strong 13-14g Butted Spoke, Silver
- Select Rim for Custom Wheel Build:
1 x Rim26_Alex
- Charger Model:
1 x 52V 4A ST-3 Charger 100-240VAC
- Controller:
1 x C4835-L10
- V3 Cycle Analyst:
1 x CA3-WPx
- Include Auxiliary Input and Power Switch:
1 x CA3_MFSwitch
- Front Motor Extension:
1 x L10_Ext-shrt
- Throttle Choice:
1 x T-Lever_50cm
- Pedal Sensor Type:
1 x PAS_12P
- Torque Arm?:
1 x TorqArm_V2
- eBrake Levers for Regen?:
1 x EbrakeWuxD_50cm
