What is the mm width of the front axle ?
Allroads
I want to install locks to the front axle and remove the quick release.
I read somewhere its 100 mm but unsure and I don't have a way to measure it.
Anyone know the size on the front wheel ?
A little unsure after looking at their site if by QR you have a standard type 10mm QR or some sort of thru axle? For the standard type you would be looking at this: https://pinheadlocks.com/store/en/wheel-locks/7-front-wheel-lock.html#/key-without_key
If thru axle look up the hub manufacturer, should be printed on the hub and find the one that most closely resembles yours and go to their specs as they should have the proper threading listed in the details.
Also you could just contact Pinhead, tell them what type of bike you have and they will probably know what will work based on a data base.
