Wanted: e-tourer & commuter
Wildmalta
Hi all
I’m looking for my first e-bike.
I currently have only ever owned mountain bikes, currently on a workhorse that suits me fine for going off road, some longer training on-road rides & occasional commuting.
My problem is that the work commute, although short is hilly and I end up sweating with no showers at work. An e-bike looks like the answer so that I can do it more regularly.
I’ve also been after a touring bike for trips of some 60 – 100km per day (40 - 60 miles) and wondering whether I can find one bike that does it all, ideally also including my current off-roading. However I’m open-minded to keep my current bike for thrashing off road & an e-bike that’s more road oriented.
A couple of questions that might sound stupid:
Obviously the battery comes out for charging, but can I still use the bike without battery? I know I’ll still have the added weight of the motor but at least I can save the battery weight for shorter non-commuting / training rides.
I assume that tourers are built for demanding conditions so should be able to deal with some off-road (not downhill) with all-round tires. I guess a sprung saddle would help with this.
I’m seeing several touring bikes have drop handlebars – I would have thought that cycling for long hours is more comfortable in a more upright position. What am I missing here?
What sort of gear range can I expect on a touring e-bike? I guess they are all single speed up front with 6 -9 speed at the rear?
What can I expect to pay for a decent model including hydraulic discs?
I’m looking at the lower end of the budget but then if I commute I’ll save fuel so willing to consider going higher if truly justified, say internal gears.
All ideas appreciated!
Thanks
You "could" use the bike without the battery, but don't expect much over 10-12mph. These bikes are heavy, even without the battery. Some people like higher speed touring, the drop bars reduce wind drag. My Haibike XDURO Trekking S RX has a single front, 10 rear. I bought it at a year end close-out for $2700. With the 500w/hr battery, the 40-60 mile range is fairly easy to hit. I like the idea of a short travel suspension fork, but not crazy about the spring unit on the Haibike. I'll likely upgrade that next year.
When did you buy your bike? I got the exact same bike on clearance and only got the 400wh battery. As for the suspension fork, I just ditched the stock Suntour fork for a RockShox Paragon. It makes a huge difference to have a real air suspension and that is the main disappointment with Haibike as they use the lower end Suntour spring fork on many of their models.
How long is your commute? If it's anything over 10 miles you should look at a Class 3, 28 mph speed pedelec. I have a 16 mile trek into the office and couldn't imagine being limited to 20 mph.
With the form factor of the bike, I think it's best to go with the comfort of straight handlebars over drop bars.
Realistic range always depends on rider weight, gear, etc. On my Bosch powered Haibike, I almost always ride in Turbo for the commute to work. On a fully charged 400wh battery, my range is between 16-21 miles. My route is flat with 100 ft of elevation gain and the bike is carrying about 170-180 lbs, that's me plus two panniers.
Without the battery turned on, you can ride it like a regular bike. It will just be a heavier bike (~15 lbs more than normal). My e-cargo bike is about 100 lbs with gear and I get about 12 mph average on slight inclines and 16 mph on flat without assist. I think it really depends on your fitness level.
Personally I think hub motors are easier to ride without battery assist because you have full range of gears. With my mid-drives, you are limited in your gears and it just doesn't ride as smooth because your chain doesn't line up as nice.
With a 13.6 ah battery (on my 48v and 36v kits), I get 40-45 miles with 20% assist on a 45 lb e- mountain bike.
To get 60 miles, I would probably be more comfortable looking using a 17 ah battery.
As for hydraulics on an e-bike, the Juice Crosscurrent S I think is around $1700 with that option. If you purchased a mid-drive kit like the BBS02 (~$1000 w/13.6 ah battery) on a hydraulic bike (around $600-$650), it will still cost you roughly the same amount. The Crosscurrent peaking out a 960 watts and the BBS02 peaking out at 1200 watts (assuming 48v * 25 amps). Both units from the same manufacturer Bafang.
You can also just add e-hydraulic brakes to an existing bike for $90. The cables already have the oil in them and just need to be bolted on to an existing disc bike.
The luna bikes look like a good value too
https://lunacycle.com/luna-alite-hard-tail/
I bought it in March, but paid $300 extra for the upgrade battery.
