Hacklemedia
Hey, guys! Today we're checking out the X3 Pro from Wallke. It was a blast to ride and had one of the smoothest PAS systems we've been on. I believe I used the word "butter" a few times.
It is a powerful Ebike and in some configurations may fall into a Class 4 electric vehicle. Make sure to check your local laws and regulations.
If you want to know more, you can check out Wallke's website: https://wallkeebike.com/products/wall...
STATS
MAKE: Wallke MODEL: X3 PRO PRICE: $1,600 BODY POSITION: Forward SUGGESTED USE: Off-road, trails, some urban
ELECTRIC BIKE CLASS: Class 4 WARRANTY: 1 Year Comprehensive AVAILABILITY: Canada, United States, Europe, Worldwide
MODEL YEAR: 2020 TOTAL WEIGHT: 63.5 lbs BATTERY WEIGHT: 6.5 lbs MOTOR BRAND: AKM
MOTOR TYPE: Mid-Mounted Geared Motor, With W-PAS Technology MOTOR NOMINAL OUTPUT: 750 watts
MOTOR TORQUE: 62 Newton meters BATTERY BRAND: Samsung lithium battery BATTERY VOLTAGE: 48 volts
BATTERY AMP HOURS: 14 ah BATTERY WATT HOURS: 672 wh BATTERY CHEMISTRY: Lithium-ion CHARGE TIME: 6 hours
ESTIMATED MIN RANGE: 35 miles ESTIMATED MAX RANGE: 50 miles DISPLAY TYPE: Key Disp, Fixed, 4.3" Color
LCD READOUTS: Speed, Assist Level (0,1,2,4), Battery Level (1%-100%), Trip Distance, Total Distance, Time, Average Speed, Max Speed, Watts, Lights
DISPLAY ACCESSORIES: Micro-USB Port on Right Side of Display for Phone Charging, Powering Other Small Devices
DRIVE MODE: Pedal Assist, Thumb Throttle, Walk Mode TOP SPEED: 31 mph FRAME MATERIAL: Aluminum Alloy
FRAME SIZE(S): 26 in GEOMETRY MEASUREMENTS: 16.75" Seat Tube 19" Reach 33" Stand Over Height 28"
Minimum Saddle Height 39" Maximum Saddle Height 26" Width 51" Wheel Base 74" Length Folded Size: 47" x 37" x 16"
FRAME TYPES: Folding FRAME COLORS: Green, Grey, Black, (NEW COLOR - Desert Tan)
FRAME FORK DETAILS: Partner 26” Front Fork, Adjustable, 100 mm Travel FRAME REAR DETAILS: 135mm Hub Spacing
ATTACHMENT POINTS: Front Light (Single Attachment Point) GEARING DETAILS: 8 Speed Shimano Altus
SHIFTER DETAILS: Shimano Acera SL-M310 Rapid Fire Shifter, Right CRANKS: Pioneer Prowheel Cranks, 170mm Length
PEDALS: Wellgo Folding HEADSET: Wallke 50.7 mm STEM: Wallke 81mm Length HANDLEBAR: Wallke 25.5” Overall Length
BRAKE DETAILS: Tektro, Dual Disk Breaks, 150mm GRIPS: Ergonomic Rubber, Locking SADDLE: Selle Royal LookIn
SEAT POST: 33.9mm Width, 300mm Length RIMS: Black, 83mm Wide TIRE BRAND: CST BFT 26X4.0 WHEEL SIZES: 26”
TIRE DETAILS: 30 PSI, 2.0 Bar TUBE DETAILS: Schrader Valve
ACCESSORIES: Seat Post-Mountable Rear Light, Flashing Valve Covers, Front Light, Kickstand, Rear Shock, Phone Holder/Phone Charger
OTHER: Locking Removable Battery Pack, Fits Riders 5’4” to 6’5” Tall, 1.4lb 2 AmpD-Power Charger, Max Total Weight 300 lbs
