My commute is taking me an average of 66min. And the first thing I noticed about an ebike is the consistency of my times.
Unless I’m up against a strong headwind, my commute is 66min +|- 2min.
I always use a heartrate monitor, as it gives a good sense of effort. I’m staying in zone 2 for my full commute, which keeps me fresh for the spin home, and to keep my legs fresh for the following days. This also gives me a good steady level of effort.
Regarding derestriction.
I think I’m happy to stick with the 25km cut off for a while. On a calm day, I’m usually left with 40% left in the battery after my 60k commute (30 each way).
66min for 30km, more than 27km/h average speed is great for a bike with 25km/h limit! But I’m surprised that you already need so much battery on a flat route with 27km/h average. My average speed for my 40km with maybe around 175 height meters with the limited Creo is about 29km/h (a bit exhausted) up to 30km/h (very exhausted). The battery usage is very low (only 13-14%, so around 10% for 30km) and so is the gain in average speed or time, without motor my average speed is already 28-29km/h. The limited Creo is quite useless or let’s say, the motor not necessary for such a route. But if you use about 3 times the amount of battery, the motor is definitely a real help.
Usually with 25km/h limited bikes slower riders use a lot more battery than faster riders as they mostly ride below 25km/h. But then the average speed is also much lower and below 25km/h. With 27km/h average on a Vado SL with straight handle bars, you’re a fast rider and normally not staying lazy below the 25km/h limit. Maybe your route has more height meters than you thought/said? Or it’s the more upright position/the straight handle bar on the Vado SL compared to the Creo, that slows down a little bit? I should try my route as well with the Vado SL to compare it with my Creo…
Have to say Jodi, the stromer looks amazing
. Now that would be fun!
I personally don't like the look that much. Also it's disappointing that Stromer cares more about design and look than about features like fenders and carrier for a commuter. But riding performance at higher speeds is incredible and beats every Bosch/Brose/Yamaha by far.
