Ukc1 pwm
stevenmp3
United Kingdom
Hi,I have two ebikes,both of them have the same set up , 72v with 3000w hub motors ,both use a ukc1 display with a 60a controller, my first bike the throttle will only go to the speed of what pedal assist you have it in,so pulling away using the throttle in a low power assit level is manageable put it in a higher level of assist and its just to fast ,the other bike throttle is flat out all the time ,it dose not matter which pedal assit you have it in ,its very diffuult to control ,is there any way to make the throttle run to the speed of what assist level you have it in ,the throttle pwn is set to 00 on both bikes thx
