fooferdoggie
Lets hope we can make this a sticky. these are the things people have found that got these two computers working right. Ok the recommended heart rate monitors are the guys. I had a Garmin hooked up when I first got the kiox it worked fine till I tired hooking my Garmin watch up then neither would work. But later I found I had to turn on the Kiox before turning on the HRM so that may have been it. But also a trek I just learned from a noter user having your HRM or at least the wahoo paired with your phone causes problems so it could have been that.
Polar H7, Polar H10 Heart Rate Sensor, Runtastic Heart Rate Combo Monitor, Wahoo TICKR Heart Rate Monitor, BerryKing Heartbeat chest strap and BerryKing Sportbeat armband.
So You need to turn on your HRM after turning on the Kiox but maybe unpairing it with your phone will fix that.
With the Nyon you need to unpair the HRM (at least wahoo)with your phone and turn it on before turning on the Nyon.
I thought it was fine having the Nyon connected to my phone and wifi or maybe wifi and the ebike connect account. It caused uses the nyon would not sync even though it said it did. So maybe you cant have both.
you need a torx t15 driver to install the nyon don't use a stubby one get a more normal length one to make life easier.
www.bosch-ebike.com
www.bosch-ebike.com
www.bosch-ebike.com
www.bosch-ebike.com
![www.bosch-ebike.com](https://www.bosch-ebike.com/fileadmin/_processed_/7/6/csm_Bosch-eBike-Nyon-MY21-Stage-Closeup-EN_a2aaf26caa.jpg?_=1592303734)
Nyon: the computer with navigation for eBikes
Whether GPS navigation, tour planning or fitness training: the smart Nyon eBike on-board computer makes a pedelec ride even more comfortable and varied.
![www.bosch-ebike.com](https://www.bosch-ebike.com/favicon-32x32.png?v=2021)
![www.bosch-ebike.com](https://www.bosch-ebike.com/fileadmin/_processed_/6/6/csm_Bosch-eBike-PL-SX-eMTB-MY2024-9207_bbe68683dd.jpg?_=1699282917)
Downloads – Operating instructions, brochures, Battery Guide – Bosch eBike
You can conveniently download operating instructions for all eBikes with a Bosch drive as well as brochures relating to electric bikes and eBike batteries.
![www.bosch-ebike.com](https://www.bosch-ebike.com/fileadmin/_processed_/5/c/csm_Bosch-eBike-navigation-Kiox300-eMTB-Statusbar-Battery-BES3-und-BES2-MY22.1_2ed6027c16.jpg?_=1649667814)
Kiox: The eBike display for performance riders
The displays can be intuitively controlled via the control unit, are compact and protected from water and dust – the ideal sporting companions.
