Kraveylicious
- USA
I’ve got a Trek Allant 9.9S which has a carbon fork. It comes stock with 180mm rotors front and rear. I’m planning on upgrading the front to 203mm as I have a very long, steep downhill to get out of my neighborhood and I often have a hard time stopping safely at the bottom. It’s not uncommon for me to blow through the stop sign simply because the 4-piston 180mm brakes don’t have enough power (much squealing can also be heard). I’ve also already swapped to metallic pads for better stopping power.
Is there any concern with running a 203mm rotor on a carbon fork that originally came stock with 180mm (no adapter required for 180mm)? Bike + rider + gear is about 250 lbs.
