Trailer Hitch
WVMontani
Fredericksburg VA
I am looking into buying a small tag-along trailer. The thing is, I have a trike and I'm looking for a trailer I can mount on the rear of the trike to pull the trailer. I've seen several hitches on the market for two-wheel bikes but I can't seem to find one for a three-wheeler.
Any thoughts? TIA.
Perhaps consider a center seat post attached trailer setup? You will likely need to "adapt" the height and length of the attachment bar (lowering it substantially) but if your requirement are not too severe (not too heavy a trailer) then this might work for you. There are unfortunately not that many options for this type of trailer.
I use this one - https://www.aosom.com/item/aosom-tr...ng-frame-galvanized-bottom~1KD92LGJC1800.html with a different (larger) box.
Any thoughts? TIA.
Here is some more info on center towed trailers for trikes.
I have a Burley Travoy which I had mounted to my seat post on my Specialized Pitch 650b. With the addition of a plastic crate, it was very effective for beach excursions (chairs, cooler, umbrella, etc.). When I switched to a Turbo Tero with 29" wheels the trailer was too close. They sold an adapter to mount the hitch on the rear rack. I actually mounted it to a MIK adapter plate so I could take it on and off.
