Currently I have 622-42mm Marathon Mondials on my cross bike. Unfortunately while on a trail the sidewall rubbed to some horns and I had a flat. I fixed the flat and since than didn't have a flat but just realized that My rear tire has a ballooned up spot on the sidewall. I assume that it is no longer safe to ride this tire.
Too bad, the mondials were holding up very well, front tire is in great shape shows almost no sign of wear and my rear tire still has some good thread(though the thread depth is visibly shorter compared to a new tire). I can just change the rear tire but I am planning to go wider so I think it is a good idea to change both.
I will be riding mostly on roads, country roads and rarely on light trails. I think the frame may allow 55-60mm but it seems to be tight so not to risk it I decided to go for 700cx50mm(29x2.0) tires.
So far I have the following tires on my mind:
Big Ben Raceguard
Big Ben Plus
Energizer Plus
Almotion
I will more likely to make a selection between the big ben and big ben plus. The tires are similarly priced but plus seem to have DD protection and slightly more rolling resistance. Is DD protection worth sacrificing some efficiency ? Mondials were not very good at sidewall protection though they had great durability. I also like a tire which will not give me trouble when climbing over parallel cracks.
I will be happy to hear suggestions on different brands different models etc.
Oh one last thing. I have been using tubes with slime and so far I have prevented 2 flats (I saw the green stuff on the tire). I had a couple of torn resistant qtubes around with removable presta cores. They are for 43mm tires , do you think I can use them for 50mm tires(these tubes can expand quite a lot)?
Big Ben Raceguard
Big Ben Plus
Energizer Plus
Almotion
