You sure can take 'em off. I need mine but you don't need yours. So, the rear fender removal I think requires removal of the rear wheel. The two black sheet metal holders of the fenders: you slide the fender out and back through them after removing the one through-screw at the bottom bracket and removing, of course, the side stays. Then SLIDE the fender out around the two black thin metal holders. Take off the front fender only, if you want to avoid a lot of extra work, because the rear wheel is a bit involved to remove and replace.
