Specialized Turbo Creo SL - a year in and today charger failed
cliveyboy
The bike charged yesterday and has every day but this evening after another dry road ride plugging in charger light stays green
and no charging happening - did a factory reset on electrics and diagnostics shows nothing? Anyone have any suggestions?
Thank you
My wife's Vado did the same thing this AM. I assume it was contamination on the connectors since everything was fine after I blew off them off.
The Vado charger uses a magnetic connector for the charger. Works well, except I keep the chargers in the shop with the bikes in the Summer. The connectors tend to pick up debris off the shop floor (and anywhere else I lay them) from other pojects so each time I need to recharge I try to be sure to clean the magnetic connectors. Today it took a deeper cleaning than normal to get the charger 'red' (I'm charging) light to come on.
Thanks will try
The SL charger (and its plug) is totally different to the Vado/Como one (it is 48 V, and the plug is not magnetic). Still, cleaning the contacts might help.
I inspected the red plug closer whilst cleaning and I noticed a very small bent thin wire in the plug. I straightened it and now all is working. It’s a very thin connector in the plug - much smaller than the 2 pins - seems likely it will happen often if this causes it to stop powering bikes.
