Right, where are you going to get a genuine Bosch BMS? Its not just as simple as positive and negative terminals.
Hi guys... I know that Bosch's batteries are 36 volt, and Lithium Ion....but I was curious if anyone knows more about the chemistry. How many cells does the 500 Wh have in it? I was also looking for a good spec sheet on them, but can't seem to find anything. Does anyone know how good their...
endless-sphere.com
"Bosch is a closed system, no tampering. They usually use samsung cells (300wh pack). These you can open and you could connect the satiator to measure the capacity. However their later batteries are sealed and tamper proof. No one has ben able to repair them or make copies, yet. I have bought a few 300 and 400Wh packs that i will experiment on. Any knowledge about the bosh batteries pack are appreciated. i also buy them used/dead packs."
"I already repaired several batteries from Bosch without any problem, from the old type or the new one. But if the BMS is out, the battery won't work anymore and you will have to pay the 700€ to get a new one "
"There is authentication between the motor controller and the BMS and the battery does not supply power without handshaking being confirmed.
The only way to use this battery is to remove the BMS and use standard one, but then it will not work on the original system."
Again, NOT SO SIMPLE.
