Ennovation
- USA
What is up, folks? Today we're looking at the R1 from Snapcycle. The R1 has a ton of power and was a fun ride on the trails, or cement. All the specs are below
Snapcycle is giving our viewers a special discount! Please use code MITCH60 at checkout.
If you want to watch our (mostly) unedited ride test, check the link below
Snapcycle Official Website - https://snapcycle.com/
Snapcycle Forums - https://electricbikereview.com/forums/forum/snapcycle/
00:00 Intro
00:15 Looks
01:07 Motor
02:02 Battery
02:36 Brakes
03:01 Gears
03:55 Extras
05:10 Essentials
05:30 Suspension
06:56 Controls
07:40 Riders
10:14 Ride Test
14:10 Outro
MAKE:
Snapcycle
MODEL:
R1
PRICE:
$1,600
BODY POSITION:
Upright/Forward
SUGGESTED USE:
Urban, Moderate Off-Road, Commuting
ELECTRIC BIKE CLASS:
Class 2 (Class 3 Optional)
WARRANTY:
1-Year Warranty
MODEL YEAR:
2021
BIKE WEIGHT:
62.6lbs
BATTERY WEIGHT:
8.4lbs
MOTOR BRAND:
Snapcycle-Specific, Manufactured by Shengyi
MOTOR TYPE:
Rear-Hub Mounted
MOTOR NOMINAL OUTPUT:
750w
MOTOR TORQUE:
85nm
BATTERY BRAND:
Samsung
BATTERY VOLTAGE:
48v
BATTERY AMP HOURS:
14ah
BATTERY WATT-HOURS:
672wh
BATTERY CHEMISTRY:
Lithium-Ion
CHARGE TIME:
5-Hours
ESTIMATED MIN RANGE:
30 Miles
ESTIMATED MAX RANGE:
45 Miles
DISPLAY TYPE:
AP7 750S
READOUTS:
Speed, Trip, Average Speed, Max Speed Battery, PAS, Lights
DRIVE MODE:
Twist Throttle, PAS
TOP SPEED:
28mph
FRAME MATERIAL:
6061 Aluminum Alloy
GEOMETRY MEASUREMENTS:
17" Reach, 29.5" Stand Over Height, 29" Minimum Saddle Height, 37" Maximum Saddle Height, 27" Width, 47" Wheel Base, 75" Length
FRONT FORK DETAILS:
Mozo Spring Forks, 80mm Travel, Pre-Load & Lockout Adjustment
ATTACHMENT POINTS:
Fender Bosses, Front Light Attachment, Rear Rack Bosses
GEARING DETAILS:
1x6 Shimano
SHIFTER DETAILS:
Shimano Sis-Index Shifter
CRANKS:
Unbranded 160mm
PEDALS:
Neco
BRAKE DETAILS:
Tektro Mechanical, Motor-Cutoff, 180mm Discs
GRIPS:
Unbranded, Non-Locking Ergonomic Faux Leather, Half Grip Right Side
SADDLE:
Justek Wide Comfort
TIRE DETAILS:
CST BFT 26" x 4", Max PSI 30
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
Horn, Integrated Front Light, Non-Integrated Rear Light, Fenders, Rear Rack
OTHER:
Channel for integrated Cabling behind Seatpost, 3-Amp charger
r1 snapcycle cruiser like himiway similar to himiway aventon 48 volts big battery removable battery downtube locking 750 watt motor powerful motor electric bike ebike e-bike long distance max range hill climb climbing hills best electric bike ancheer electric bike electric bike review fastest electric bike best electric bikes cheap electric bike fat tire electric bike fast electric bike
