Sarah Burnett - Giant won’t turn on
I have a giant stance e+2 2021 and it just cut of won’t turn back on no error codes or anything tried a new contorller new battery and still nothing gonna change the discharge connector next and fingers crossed I have life
Dam u should have brought it to a dealer straight away alot of the downtube batterys were called back because of a connection issue and then they sent a bracket that goes over the connectors,but my bikes a horizontal battery thatsits under the backrack there known to be the best in terms of reliability i think my problem is a easy fix if the display would stay on long enough to connect to the Bluetooth i could do a check.what does your app say?
So it was under warranty and they gave u a new bike? Giant put there own stamp on the motherboard and i read somewere that someone swapped out the board and put the exact board but the proper yamaha version and still wouldnt work.but you are garunteed to get the red light if the boards gone this was confirmed by giant themselves.id say they seen something alot more serious to give u a new bike im guessing a crack in a vital place Plus whatever your problem was.
My issue was the bike shutting off. Tried a bunch of things but the bike was only 3 months old and they replaced it.
Thats wierd but i know alot of them were giving battery trouble connectors not connecting and alot were called back,i got my bike back working today so this probably is a update i received arefresher pack yesterday new vearings etc grease and notice one of the bearings was defo on its way out as there was the slytist bita play in the crank not enough to notice when everythings tightened up,now i know there a syncdrive system but i didnt think a bearing would cause a display to not turn a motor on or give a sign atleast but after i done the work on it fresh grease and i notice them motors dry out alot quicker than most so it got a good going over and everything tightened back as far as the lockring i then hooked it up and its working lights staying on all modes select went on the app done a check got the 3 main ticks however i will still bring it in when my shop opens as its closed due to refurb of water damage and get it properly plugged in i seriously cant except it was a bearing as i know theres lots out there whos scrapped there motors because of this.ive video'd everything ive done even tho its way outta date but maybe itll be of some use to the shop as im sure they get this alot,these motors are very well built motors with metal internals something other companies are only doing recently imo there to sensitive as a standard road bike and mines not a pro but as soon as u put pressure on that pedal your gone Only the modern cx from bosch has done that with me and this motors atleast 4yrs older i will check back with whatever the dealer has to say when the time comes as for now its going back on the bike and ill be looking for a extra battery for it ✌️
