tubazoltan
Hi,
I have a Load 60 with the Enviolo rear hub. The frame is the 2018 model, with the old rear triangle. The bike came equipped with an Enviolo rear hub, now I am about to install a Rohloff hub. The two shifter cables for the Enviolo run on the right side of the rear triangle, but with the Rohloff the two shifter cables should be on the left side (on the same side as the hydraulic hoses for the rear brake). As the Load did have a version factory-equipped with the Rohloff (suposedly at least, as it hes the Rohloff dropout, with the long slot on the left side), I am sure they have a factory-standard-way of routing the cables to the Rohloff hub on the left side. However, I can not find a picture of this on the internet.
In case you need identification:
This is the new rear triangle (here the cables run inside the frame):
And this is the old one, which I have (actually I have this exact bike):
If any of you has a similar Load (like this blue one) with the Rohloff, would you be so kind as to provide me with a few pictures of the cables running from the handlebar to the hub? I could of course solve this with cable ties, but I am more curious of the "neat way" to do this.
Thank you in advance!
Zoltán
Zoltán
