Regenerative braking requires a motor/generator which is a Direct Drive hub motor. DD e-bike motors are very heavy, rare, and the regenerative braking control must be complicated because you would rather like to be coasting when not pedalling instead of be slowed down by the generator. I have only heard of only one well known brand that tells you they can do it, and that's Stromer. We might ask
@jodi2 how the regenerative braking works in his Stromer. (What I hear is regenerative braking makes very little sense for e-bikes as the moving mass of the object here (bike + biker + cargo) is relatively small, bikes operate at relatively slow speed, and very little of the kinetic energy could be recovered, especially with the low efficiency of the generator).
I agree to your last sentence in brackets. But as I wrote this this year somewhere in a forum (but I don't remember where...), let me ask, was it somewhere here and you now repeat my phrases or do you get this arguments from somewhere else? That we know how many independent "sources" we have... I'm not sure if It's clear what I want to say in my bad english. If not, never mind... ;-)
I'm not completely sure why there is no/never reg. braking in geared (middle) ebike motors and only in a few hub motors. But it needs a relatively big motor (for a bicycle) to produce some braking and charging power and also a big battery to stand the currents during regeneration which can be quite high. The rear wheel of my stromer St1x overall has about 8,5kg, so only the motor about 6kg. So the highest Stromer model motors 6,5-7kg I guess. Stromer batteries are usually 814 or 983 Wh and about 5kg. Total weight of a Stromer 28-30kg.
So for example a Specialized SL drive is definitely not suited for reg. braking. Also the small rear hub motors which have become common (at least in Europe) in city&trekking ebikes the last years never have reg. braking. No matter if it's a one for $1000 from the disounter or a $8000 high end ebike. When I was looking for the first time for assist drives, I was quite disappointed about this. Together with the really bad uphill capability of a small hub motor these assist drives aren't for sportive usage, more for cruising at 20km/h through the (flat) city. Geared middle motors are the choice for small assist drives for sportive bikes/usage.
More than a decade ago I lived near Darmstadt/Germany and had good contact to Riese&Müller, when they started with BionX (rear hub) ebikes. These bikes had similiar power like the actual Stromers and they already had reg. braking. And the motors died like mayflies exactly because of this. I guess this was one of the reasons for the fall of BionX and also Riese&Müller had great losses because of the unreliable BionX motors. I think this “BionX trauma” was the main reason for Riese&Müller to switch to Bosch and to stay so strictly to Bosch, now more than 10 years I think. I’m still waiting for the return of at least a few 45km/h models with hub motor and wrote two times to R&M, pointing out that it reliable rear hub motors are possible today, even with reg. braking. But never an answer, the trauma still seems to be big at R&M…
The main problem was afaik that the motor controller was inside the motor and overheated very easily. Also the first Stromers like (the old) ST1 had this problem and was far from the reliability of the later models starting with the ST2 (I think in 2014). But at least the ST1 motors did not die completely, just stopped motor support and needed a long time to cool down and recover or a short visit at the LBS.
With the ST2 the motor controller went outside the motor/e.g. in the frame and problems were gone. Actual Stromer models since ST2 have no problem with reg. braking or overheating, even if you ride the longest alpine passes up or down. If motor or battery overheats, power is reduced, but smoothly and it comes back soon and also smoothly. And it needs quite a lot of height meters, low speed/rpm and a hot day before this happens (due to the quite big motors).
Stromer also has combined the reg. braking nicely in the brake levers. Pulling them softly only activates the reg. braking, if you pull harder, the real brakes join. You can also activate the reg. braking via button in several levels, the higher ones quite strong. If the battery is full, simply almost nothing happens/no braking by the motor, but no damage to battery, controller or motor.
Ok, enough ads for Stromer... I know only one more ebike brand which is capable of reliable reg. braking, that is "Klever" which has similar ebikes like Stromer (not sure if they're sold in other countries or continents). There maybe a few more, but I'm not sure and if they work reliably.
But after all these fantastic details, the effect/the gained range on my Stromer is quite small. It’s difficult to measure, but I guess for me in my area (quite flat, but not like the Netherlands...) it’s maybe 2%. With some more hills maybe 4%. So it’s nice to have for me and it’s great to see that it works without any worries, but it’s not really necessary. It may be more for someone mostly cycling in a really really hilly area and of course it will be much more if you go only up and down mountains. But for average use it’s maybe 2-3% on a Stromer.
We also have a (fully) electric car since 2019 and even if it’s one of the lightest on the market (a BMW i3 with carbon frame) the effect is much much higher. In the same area where I gain maybe 2% of range with the Stromer, I gain about 10% with the car. In hilly areas it’s easily 15%, if it’s very hilly maybe 20%.
But I agree with mschwett, that the effect/the gained range in % should be similar on an ebike and I’m not sure why the difference to the car is so big...
btw, the necessity of motor and battery big enough for reg. braking is one (of several) fails of (most) hybrid electrical cars. The small motors can’t produce much reg. braking energy, but the small batteries already struggle with these currents. The high load during driving or reg. braking and the much higher number of full charging cycles (maybe 1-2 per day compared to 1-2 per week in a full electric car) kill the hybrid batteries about 10 times faster (in mileage). But as most hybrid cars here are with 2-3 years leasing (and a lot of grants), nobody cares... :-(
