I did the Topeak Uni Super Tourist Fat tire rack with quick track system (66 lbs capacity for rack). I don't know if the Rad Rack weight limit is for the Rack only, ebike, or both in combination? I never got close to 66 lbs limit with my Topeak MTX Rack bag with fold out panniers. I probably maxed out at 20-25lbs if I add a spare battery, water, tool kit, spare tube, and winter gear in the top bag+side panniers. I also have a commuter back pack I wear with about 15-20 lbs of stuff when I commute (work cloths, lunch, riding gear, electronics).
Don't know if Rad has changed its controller with the 2019 versions? I can adjust my controller up to 40 km/h or 24.8 mph. I usually set my Radrovers to 36 km/h (22 mph) at PAS 3 for my work commutes. I can hover around 18-22 mph depending on incline and head winds. I didn't like having the power cut out at 20 mph when I could maintain 20-22 mph at PAS 3. I can get up to 24-27 mph on some down hill runs if I pedal like crazy. The gear ratios on the Radrover isn't set for speeds +22 mph.
The only major thing I had to do is upgrade my brakes to Spykes TRP and Jagwire MTB cables because of my commuter speeds. The rad brakes were noisy, needed constant adjustments, and had longer emergency stopping distances compared to the Spyke brand. Spyke TRPs are plug-n-play replacements along with the Jagwire cable replacement.
