So this hub, the one I just laced up for a 26x4" fat tire conversion to 27.5x2.8" project, was just my imagination?
Sun Ringle Abbah S.O.S XC Front MTB Hub. Also, graphics may vary slightly from that which is pictured. Hub width: 100mm QR(QR skewer not included). Hub Body Material: 6061 T6 Alloy Hub Body. Brake Type: Disc, 6-bolt.
www.ebay.com
same story on the rim I used?
The anodised versions of our SAS rims can also be used with rim brakes. Naturally, the anodised finish will wear and reveal the silver coloured aluminium. SAS 27.5 Rim. Our SAS rim needs no introduction and has a proven record for re-defining what strength is.
www.ebay.com
Or this one I'm planing on using for the rear?
With its bold 30mm wide profile and its strong construction, EX 830 is the go-to rim for bike park users and gravity and speed addicts. Single eyelet. 6061 aluminum alloy. ERD: 558.5.
www.ebay.com
I believe there is such a thing as a 36 hole rims setup using 13g spokes. All you need to do to confirm is walk over to your RAD or most any other production e-bike using non proprietary parts.
