My word of advice to you is to contact Priority and describe exactly what's going on & what steps are needed to have this inspected and repaired under warranty. Priority is a direct-to-home seller, so I am not sure what they may have in place as far as a repair network, but you need to find out. At this point, you can do a visual inspection of the mid drive system, wire runs, (not sure if this bike has a spoke magnet for the speed sensor, but you need to find out). Check for anything out of the ordinary and then contact Priority as per what the next step to make repairs would be. Any error codes stored in the display? How does one extract error codes with this drive system?
Disregard Indianajoe's advice about poking around with a volt meter. Unless you know what you are probing, you will cause a short, disabling the drive system or battery and voiding your warranty.
