6zfshdb
- USA
- City
- Northeast Pennsylvania
This is such a minor problem, I wasn't going to post this until I read in another forum of someone else having this same issue with a Pedego Interceptor. So, in case it might help someone, here it is.
I often carry a lot of weight in my panniers and rear rack bag, sometimes as much as 40 pounds. With that much weight on the rear, it tends to pull the bike over no matter how the kickstand is adjusted. I tried a variety of rear frame mount kickstands with limited success. None of the ones I tested were as well built or had the solid feel of the OEM Pedego stand.
The problem is the OEM Pedego kickstand swings too far forward when deployed. It provides little support for weight on the rear of the bike. I found by adding a 3/16" thick aluminum shim to the mechanism, the kickstand touches the ground about 4" further to the rear. This makes a huge difference in balancing a rear heavy bike.
Unmodified
With shim
I cut a piece of 1" aluminum angle as shown and screwed it to the kickstand frame. This way, It could be removed if the experiment didn't work out. It worked so well that I'm going to epoxy a flat piece of 3/16" aluminum in the mechanism instead of using a screw.
Unmodified
With shim
