Allan47.7339
Lessons learned as a former commuter. Most traffic signals use an induction loop to trigger for vehicles. You can frequently see where they've installed them in the pavement. If it is a 3ft diameter circle, you want to be on a chord about ten inches from a tangent point parallel to travel. Some cities will put a bicycle mark at this point. If it is a rectangle, usually riding on one side leg will trigger it. If they have the signal cranked down so it does not detect a bicycle it will probably have trouble detecting a motorcycle. Sometimes they put the loops a two or three car lengths away from the crosswalk so if you know where they are you can slow down as you ride over them to trigger the light. I was told by an EE friend that even aluminum pedals should be able to trigger an induction loop set correctly.One benefit I didn't see coming: Lots of big intersections with very long lights here. If there are no cars behind me in my lane, the green light I need to get through may never get triggered.
