Off road all day
Now this is what i'm thinking, i have a cutoff power brake lever, i actually don't need it It's all good without it.
I turned to the left sharply and the motor cut out quickly about 3 times, this puts the right handle brake cut off high. Any moisture can run down and cross the connection, cutting off the motor. Any guesses.
Its a frame mounted motor, the throttle, batt, controller are all separate. I have noticed the past week connecting the batt to the controller causes a small spark, pretty sure that's not good.
Moister in the controller? The connections where swapped out for much larger capacity ones.
Guaranteed all wires and connections far exceed factory specs.
With 3 days of wet snow on the way i have no way to test anything, definitely going to unplug the brake cut off first.
