Juiced
OceanCurrent has beach cruiser styling, very wide sweeping back handlebars, both high and mid-step frames, 26" wheels with wide 2.35" tires for a lower riding height and comfort, a 48v rear hub motor, mechanical disk brakes, weighing 51lb, for $1300. It has pedal assist with a torque sensor that modulates power depending on how hard you pedal, and a thumb throttle. The battery is mounted in the center of the bike on the down tube that distributes the weight.
Raleigh
Superbe iE has classic bicycle styling, standard width swept back handlebars, both diamond and step-through frames, larger 700c/28" wheels with 1 5/8" regular bicycle tires, a 48v rear hub motor, rim brakes, fenders chainguard and rack, weighing 50.2lb, for $1500. It has pedal assist with a cadence sensing motor on/off switch, no throttle. The battery is mounted on top of the rack and with the motor in the rear wheel hub the handling may feel a little rear heavy. Another model, the
Raleigh Retroglide has cruiser styling, 26" wheels with wider 2 1/4" tires for lower riding height and comfort, a 48v Currie mid-drive motor so weight is distributed, an optional
boost button throttle, but is slightly heavier at 57.5lb, for $1900.
If you are interested in a
crank forward ebike the Luna Smoothie is a conversion of the
KHS Smoothie cruiser frame, with 26" wheels and a 3-speed IGH with the step-through frame for $1780. The low adjustable seatpost, 26" wheels, and low step over height of the step-through frame provide an upright riding position, and the powerful BBSHD mid-drive motor is a $100 option that would get you up any hill, but you don't get a warranty unless you spend more, also the photos on the Luna website don't show a chainguard so if desired you would need to contact Luna to ask if the stock KHS chainguard can be made to work with their conversion or try to make one fit using frame clamps as the typical bottom bracket mounts won't work with a BBS motor, also there's no Luna Cycle shop network unlike with Juiced or Raleigh so you would need to find a KHS dealer to test ride the frame, and an independent ebike shop that services bafang mid-drive motors.
