Light connector on ENA 48V1000W EUNORAU kit
GaserX
Hi, got the kit above, working quite well. Thing I cannot figure out is the headlight connectors, using the display controller to turn on light, will not energize those connectors with 12v or anything. My VDC guage just keeps jumping. Anyone know how to connect a 12v , 2-wire light to this connection? Why a red and black, with each having 2 wires, 1 red and 1 black? I'm confused, can anyone help?
Thank you
Got some info from the vendor, seems the black connector is for a front light and the red connector is for a rear light. My problem is I already have a 12v DC light I want to use and these are only 6v. Can I use both and with some kind of con/in-verter create 12v from the 2 x 6v connections?
Thoughts?
From the vendor... "The red one is the rear light connector, the black is front light connector. There are two wires in the connector. Inside the front light, the black is GND, the red is QD. The rear one, the black is GND, the red is WD".
www.eunorau-ebike.com
Little more info wondering if anyone knows what the connector is for the lights? I want to buy the opposite connector so I don't have to cut the wires. Anyway, I used a 12V DC relay connected into these switches to then power up my 12v driving headlight using a separate 20v battery. Holding the switch on my controls activates the relay and switches on my headlight perfectly! Just want a connector rather than cutting wires. Anybody have any ideas?
