Kiox and USB Power to charge an accessory
Luto
Hi All,
On paper the KIOX has a micro USB port that should output enough to charge a small head lamp or top off a cell phone.
So I tried to hook one up only to find that physically, I cannot get a cord plugged into the KIOX and place the KIOX back on the mounting frame. The plug interfered with the fit onto the mounting frame. I had a pretty minimal plug head.
Anyone solve this?
Thank!
Hi All,
Anyone solve this?
Thank!
I bought a standard micro B USB "On The Go" cable from an ordinary computer store. The micro B plug is small enough not to hinder the Kiox mount. The other end of the cable is a "standard" USB socket.
The mobile is then connected (plugged in) to the above cable using the mobile's charging cable.
I actually used heat shrink to make the plug/socket connection stable and water resistant.
Cheers
Hi, I am using the Kiox to power my Garmin Edge Explore. You need a small cable with two micro-usb connectors. Just ordered one from eBay.
