Rkpine
I bought an ebike conversion kit, 48v 1000 watt rear wheel with LCD. I removed the pins from a wire connector from the brushless hub motor to the controller. When I replaced the pins in the connector, I messed up. I switched red and black and on the 3 pin row yellow and blue. When i eventually built the battery 50.2 v 20ah, I turned everything on and the bike does not work, does not light up the lcd. I found the problem when I replaced the controller with a new one. I do not know what I could have blown up. I assumed it was the controller. Could it be the LCD? (SW900) or did I wreck the motor? How do I fix this. I am determined. Thanks for the help. Rkpine
