Hello Everyone,
I am requesting some assistance on a hydraulic disc brake on my new Aventon Aventure. After receiving the bike, I had a bit of a struggle mounting the front wheel due to the fact that the brake pads were so close together. Ultimately, I was able to separate the pads enough to allow the disc to seat into the caliper. However, I subsequently found that there is no play/travel in the front brake lever; the moment you begin to squeeze the brake lever, the front brake engages immediately and bite, unlike the rear brake (or the brakes on my other Aventon) which have what I would describe as a more common amount of travel before you feel the brake engaging. This issue makes it difficult to apply light braking to the front brake because of the lack of travel with the lever. There are no other issues with the brakes. I contacted Aventon customer support which thankfully advised that they would cover the expense of having the bike shop adjust the front brakes. They indicated that it might be air in the brake line and a brake bleed would hopefully resolve the issue. Although Aventon will cover the expense, I was wondering if there was an easy adjustment that I could make to the front brake myself rather than having to haul the bike to the bike shop for a couple of days. If bleeding is required to resolve the issue, that is something that I would not try myself and would take it to the bike shop for sure. For info, the brakes are BENGAL ARES 3. Thanks in advance.
