How to measure battery voltage with a good meter
My riding battery I keep at 80%, and only top off right before a ride, about two hours. Coming back with, say, 50%, I throw in three hours, which will get it to the 80%.
By the bye, I've seen a suggestion of using a USB fan (hooked thru the port) to get a battery DOWN, which makes good sense tor those of us in frigid climes whose next decent riding day might be a week or two away.
That is a good idea!
Learning as I go...I went for a ride this afternoon without my phone as its battery was down. Never occurred to me that I could have charged it off my bike battery as I rode - until I was out and about.
SMH.
Polarity not all that critical when taking a voltage reading. You're just going to get a positive or negative in front of the number you're really interested in. Unless you're doing something polarity critical, who cares?
My bike lives in a garage/work shop. The only time the battery is removed is when doing something like changing a controller or other major electrical work. Point being, many (most?) displays have a pretty good voltmeter built in. That's all I ever use.
I like to charge at 47-48 volts as well. There's not a lot left in them at that point, and common thinking has it that's good for the battery. I would mention though, that most controllers have a low voltage cut off built in to them (LVC), and that value is something closer to 3.0 volts per cell (40v total). That's the drop dead, don't let it get any lower than that because you're going to damage it value. Nice, because the controller's not going to let you....it's going too shut you down!
Hey
I keep getting voltage readings (volt meter) when the battery is off! It's usally a few volts lower than when the battery is on but, should I be getting a reading when it's off?
BTW the hand held agrees with the bike display when the battery is on.
As long as your voltmeters agree when the battery is on, you're fine (hand held and display).
Still, just curious. You mean the battery is turned off, or the battery has been removed from the bike? Where are you taking your voltage readings when the battery is off?
The battery is on the bike. The battery has a button that "is supposed" to turn the battery off,... yet when I plug the meter probes into the discharge connectors, I still get a reading, usually 2 v lower than when I turn the battery on.
Just seems strange to me that I am getting any voltage from the discharge cables when the battery is turned off .
Also seems strange that there is a voltage difference.
This battery was impacted during shipment, so that's why I am a little concerned.
Don't be.
If you took the time to track down the source of the voltage you're getting, it'll just be a capacitor or something holding an ultra tiny amount of power.
What are discharge connectors?
