Bike_On
Here is my 2c breakdown.
** Revised **
Level 1. less than $1500. Budget quality. Expect some lead or junk. Bottom line components and back-end heavy designs for low cost. Not safe at higher speeds.
Level 2. $1500-2500. Entry level ebike quality=> mid range for regular bikes. Low speed output or limited to 20mph, low power (250-350W), Frame/fork may not be optimum for weight and speed. Standard bike gearing is adequate for a 20 mph top speed. Standard 36V, 10Ahr expected. Adequate design for light use.
Level 3. $2500-$5000. Higher quality components, but may not be all high quality. Entry level performance class. Designed for higher speeds (20-30mph) with power performance of 250W, up to 500W average power. Standard gearing may not be adequate, nor match speed range. Hydraulic disk brakes desired, but not typical. Frame design and suspension designed for ebike's higher weight and speed. 36-48V, 360-600+ Whrs. Adequate design for moderate use.
Level 4. $5000-8000. High level performance bikes. All should have high quality, specific applied componentry. Frames and suspension can support and perform under higher power and attain high speeds of 30+ mph with solid handling. Designed for hard use and lasting value. High quality hydraulic disk brakes and suspension. Some specialty applications. Expect 500W min average power (for a hub) and 1200W peak. 36-48V, 500 Whr min.
Level 5. $8000 and up. Same as level 4 with specific style/function bikes, customized metals, paints, frames. Boutique companies, high power and high performance. Expect 750W- 4500W of power. More carbon and high end components. Will have larger Li batteries, 800+ whrs, and can justify some of the costs. 36-48V+, 700 Whr min.
I had labeled the Specialized Turbo as a $4.5-5k bike. (Because of no suspension) That was more of a value price than a selling price, IMO. With a DDhub putting out 500W cont and 1000W peak, and given it's quality, it is a category 4 on quality and power and the $6k price price not rediculous.
** Revised **
