For those who do, how did you learn to do so?
Is there any instructional video on how to do?
Try that in the dark after a long day at work...lolI've changed the rear four times now for flats on my ST2. 2,700 miles of cycling.
It is pretty difficult for one person to do it on the side of the road without a stand like in that video.
A few tips;
Take out the battery. Reduces the weight considerably. Plus you should power it off anyway.
Turn the bike upside down. Be careful what surface you do this on obviously. I like to put a jacket under the handlebars and seat if I have one.
Make sure you are in the highest gear (smallest rear cog).
When you remove the axle there is a metal washer on the side you extract the bolt from. It can fall out as you move the bike around and you cannot lose it!
Rotate the wheel so that you can see all of the power plug that goes into the hub motor. It has a metal half ring that is recessed but that you pull up and use as a handle. Move the wheel so that the whole connector is exposed. Pull on that handle and the plug that connects the power comes out. Much better than cutting cable ties like in that video.
Now you can remove the wheel and fix the flat. Because the tyre is so big it comes off very easily. In fact that makes it difficult to get back on. The weight of the hub motor makes you want to stand the wheel up. But if you do that the tyre has a tendency to fall back off again. Keeping the tyre on with an un-inflated tube is a pain.
Putting the wheel back on is the hardest part as everything has to be aligned - and it is heavy.
The trickiest part is lining up the motor connecter with the cable. There is no play in the cable so you have to rotate the hub independently of the wheel so that it is in exactly the right place as you slide the wheel towards its setting. But you have to plug in the power before finally settling the wheel in place because the frame blocks the socket.
Also make sure you keep an eye on the disk brakes. The disk has to go between the pads obviously but that means there is little to no wiggle room.
Before tightening up make absolutely sure that the power cable is slotted behind a small cable guide on the frame. If you don't do this the cable can rub on the wheel and will eventually break and short.
Finally put the axel bolt back in - making sure the washer is still there. You will likely need to move the wheel up and down slightly to set the bolt into the thread on the opposite side. But when you do it fully aligns everything perfectly.
Try Park Tool Tire Boot, smaller and thinner than a credit card. I've used them, work great!I have kevlar tires and Slime, but nonetheless, I had a sidewall blowout of my rear tire. No patch or spare tube could help me there, so I ended up walking the bike about three miles back to my house. Luckily, I was not further away.
Someday I want to try out the Tannus flat free tires and not have to worry at all: http://www.tannus.com/#intro
That looks like a good thing to add to my trunk bag. Some day I may be thanking you on the side of the road![]()
