Toyota is trying to communicate some important information that is presented unclearly in English. Perhaps, the original message is clear in Japanese?
global.toyota
Production levels are a pathetic joke. How many employees are needed to manufacture ten cars per day for the entire nation of Japan? Are the cars manufactured by the engineering department? Is this some sort of cruel joke? What are they implying? I don't get the point. Why bother? What is wrong?
This reminds me of IBM's initial demand prediction for the PC. This production level suggests to me that some senior executive is ultra conservative and his job is threatened by the release of the RAV4 Prime.
I would not buy a RAV4 Prime until production levels equal demand. The RAV4 Prime stands as my reference model for a PHEV. The product is very sophisticated and expensive.
Without adequate replacement parts, you might be without transportation for months. Any consideration about buying a RAV4 Prime must be made with a very high degree of suspicion.
Toyota Launches New Model RAV4 PHEV | Toyota | Global Newsroom | Toyota Motor Corporation Official Global Website
Toyota has launched the new model RAV4 plug-in hybrid electric vehicle (PHEV) through dealerships in Japan on June 8, 2020.
Monthly sales target for Japan 300 units
- Fitted with a remote-controlled air conditioning system. Air conditioning can be switched on using a smartphone application or a smart key. The car interior can be heated or cooled for up to 20 minutes, using electricity from the lithium-ion battery.
- Even with the inclusion of a large lithium-ion battery and an emergency spare tire, the new RAV4 provides 490 L (VDA measurement method) of luggage storage space, more than ample for a SUV.
*6 | Power supply is terminated if the remaining battery power falls below a certain level |
*7 | When HEV power supply mode is used continuously at the maximum output of 1,500 W |
*8 | A subscription-based PHEV recharging service provided by Toyota Motor Corporation |
*9 | As of February 2020. |
*10 | As of February 2020. Number of regular charging points installed in collaboration with Nippon Charge Service LLC. Websitehttp://www.nippon-juden.co.jp/ |
*11 | If a grounded outdoor outlet is available, it can also be used. A locking electrical outlet must be replaced with a high-durability outlet.It |
- Adequate temperature of the lithium-ion battery is maintained using an air conditioning coolant. Reliable battery performance is enhanced by avoiding use under high temperature that accelerates deterioration and by appropriately controlling the battery charge.
- The air conditioner employs a heat pump system that uses the heat from external air to raise the temperature of engine coolant water to heat the vehicle interior. When the air conditioner is on, it controls power consumption and reduction of the BEV driving range.
- Enhancing the convenience, unique to PHEV
- The new RAV4 comes with a maximum of 1,500 W (AC 100 V) external power supply function as standard equipment that are useful during blackouts and other emergencies, and for outdoor leisure activities. In addition to an accessory electrical socket in the luggage compartment, it is also equipped with a vehicle power connector which can be plugged into the regular charging inlet at the rear (right) of the vehicle for use as an external power socket.
- It offers two settings, either BEV or HEV external power supply mode, which can be selected according to the intended purpose. BEV mode*6only
- uses power from the battery, whereas
- HEV mode starts the engine if the remaining battery power is too low,
- enabling approximately three days'*7 of power supply on a full gasoline tank.
- Accessory electrical socket
Vehicle power connector- The RAV4 is readily able to provide regular power supplies at home or outside as a standard feature. The supplied power cable (both AC 100 and 200 V) can be connected to an electrical socket for recharging. Away from home, the PHEV recharge support*8 can be used to charge at G-stations located at around 4,200*9 Toyota dealers, and at around 10,800*10 other regular charging points across Japan.
- Air conditioning can be switched on using a smartphone application or a smart key. The car interior can be heated or cooled for up to 20 minutes, using electricity from the lithium-ion battery.
*6 Power supply is terminated if the remaining battery power falls below a certain level *7 When HEV power supply mode is used continuously at the maximum output of 1,500 W *8 A subscription-based PHEV recharging service provided by Toyota Motor Corporation *9 As of February 2020. *10 As of February 2020. Number of regular charging points installed in collaboration with Nippon Charge Service LLC.
Websitehttp://www.nippon-juden.co.jp/*11 If a grounded outdoor outlet is available, it can also be used. A locking electrical outlet must be replaced with a high-durability outlet.
